hi everyone i need help on this emachines d725 board code:HM40-MV 08242-1M 48.4BW01.01M cannot turn on on power button but when short on pin7 on power button laptop is on and boots fine i noticed there is on 3.3v on power button but have 3.3v on pin7 pn the power button connector on motherboard.anyone can help on this please i have attached the image
emachines d725 cannot turn on with power button
Re: emachines d725 cannot turn on with power button
@meritosari thanks for the response i can turn on the laptop if i short pin 7 and 8 but when i press power button cannot turn on. there is no 3.3v on power button switch but on pin 7 and 8 there is 3.3v.where should i make jumper wire for this?
Originally posted by String2016 View Post@raajkumar where to put jumper?Last edited by raajkumar; 10-21-2017, 02:13 AM.
Originally posted by String2016 View Posti test the ribbon continuity is good but when i plugged in to power button pin 1 on the board and pin 1 2 3 on the power switch have continuityLast edited by raajkumar; 10-24-2017, 12:06 AM.
there is no capacitor or small transistor on the power board but there is led light i checked also pin 123 beeping to ground on the power board and when checked with continuity test the led light the one on the power switch button when i touch both sides with probe it lights up with orange light and the same with led number 3 when i touch it lights orange.but the other led light not it has 6 led light on the power boardLast edited by String2016; 10-24-2017, 03:28 AM.
Originally posted by String2016 View Postthanks you mean from pin 7 and pin 8 on the motherboard to power button switch?
- Always make habbit to type message with coma and dot in your sentence.
- This mobo was eaten by age, so many components on it could be has change value or leakage.
- I think that make jumper to shorted pin 7,8 and 9 together at POWERCN1 only as last option if problem still persist. (pin7=TP_LOCK_BN#_1, pin8=PWRLED#_R, pin9=KBC_PWRBTN#_1) think here...............
- Make sure you have 3V on 2 pcs triangle G1 near POWERCN1. Try short G1, and see what result. If you can switch ON, then problem on ribbon cable and sub board power button.
- I would prefer to check a few components which connected to KBC_PWRBTN#, such as RN47 and RN1, maybe "resistor network" was open or change value.Attached Files
Originally posted by meritosari View Post- Read the schematic if you want to repair motherboard laptop/computer, since all part on mobo was Surface Mount Devices type. the motherboard has more 5 layer inside it. Wrong to take line can be causing other problem.
@meritosari thanks for the schematic the problem with this is the power board switch because as iv'e mentioned above that i can power on the laptop if i short pin 7 and pin 8 on the and near G1 on the CN1 have voltages.the problem with this is the power switch board
