I'm working on this little Vizio LCD and it's got me stumped. What's happening is that when it is first plugged in, I can press the button to power it up, which it does, but it then promptly freezes without lighting the backlights or displaying anything on screen after that point. From here, no amount of tapping or holding of the power button will shut it down or elicit any further response.
I tested the power supply for standby voltages and everything looked like it should be within protocol, so I figured that this was indicative a bad mainboard. Upon replacing the mainboard, the same exact symptom is occurring, however. Is there anything else that might be good to check? Or is it most likely that the replacement board had the same exact problem?
