Old 10-19-2019, 04:24 AM   #1
nbdy
City & State: Sv.Nedelja,Bestovje
My Country: Croatia
Line Voltage: 220VAC/50Hz
I'm a: Hobbyist Tech
Default Philips 32PFL3606/58
Have a 32pfl3606h/58 from philips,which when I plug him in turns on,and then off (1-2 sec) ...
The PSU board looks OK,no damaged caps,no damaged fuses ...
Tryed to measure the 24V,12V,5V where I on 5V get 12V ...
The picture was ok (the first time I pluged him on it was on for about 1-2 minutes) ...
No power led,no standby led ...
any advice
nbdy is offline   Reply With Quote
Old 10-19-2019, 04:58 AM   #2
FrozenHaxor
City & State: Warsaw
My Country: Poland
Line Voltage: 230VAC 50Hz
Default Re: Philips 32PFL3606/58
Please clarify - does it turn on right now for a short period but not show any LEDs?
Post pictures of the TV back and the PSU close up.
FrozenHaxor is offline   Reply With Quote
Old 10-19-2019, 05:21 AM   #3
nbdy
My Country: Croatia
When I plug it in (220V) then the led turns on for a sec and all turns off,can't power it on again ...
https://www.dropbox.com/sh/v328onhbj...84X-kaa8a?dl=0
Unpluged the mosphets for testing
Old 10-19-2019, 06:25 AM   #4
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
Can you give all the voltages measured at the connector CN902 pins 1 -> 14
dick_barton is offline   Reply With Quote
Old 10-19-2019, 08:04 AM   #5
nbdy
My Country: Croatia
ENA - 50 mV
DIM - 270 mV
12V - 0V
24V- 250 mV
5V - 4.74V
S/B - 0V
Old 10-19-2019, 12:59 PM   #6
dick_barton
My Country: Wales
Disconnect the power supply from the main board and on the power supply connect +5V to S/B using a 1K resistor and also another 1K resistor from 5V to ENA and check for 24V
It's better to post your pictures on your post using Go Advanced and then "manage attachment".
Old 10-19-2019, 01:21 PM   #7
nbdy
My Country: Croatia
12V - 0V
24V - 0V
With both S/B and ENA to 5V ...
The PSU is disconnected from the MBO ...
The measures in 5. post are made without the MBO ..
Rechecked the C933 and C934 both OK ...
Old 10-19-2019, 02:40 PM   #8
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
There are 14 pins on the connector, you did not report all the pin (GND not needed).
What is pin #14?
Do you get about 380 ~ 400 VDC when measure between the two legs of the main filter cap in the hot side when you force on S/B pin?
Old 10-19-2019, 05:20 PM   #9
tvtimmy
tvtimmy's Avatar
City & State: milwaukee,wi
My Country: usa
Line Voltage: 120VAC/60HZ
Try unsoldering one leg of all the diodes and measure them.
tvtimmy is offline   Reply With Quote
Old 10-20-2019, 02:20 AM   #10
nbdy
My Country: Croatia
@budm PINS are :
ENA
DIM
12V
12V
GND
GND
GND
24V
24V
S/B
5V
5V
empty pin
INV_OK - that one i mised
the double/triple pins are shorted
Where should I get 380-400V ?? On the lamp exit ??
On T803 on hot side I don't get 380-400V
Old 10-20-2019, 02:54 AM   #11
dick_barton
My Country: Wales
Use your meter set to DC volts and connect the probes on each lead of the 100uF, 450V capacitor.
Old 10-20-2019, 03:17 AM   #12
nbdy
My Country: Croatia
I got 323V DC
Old 10-20-2019, 06:09 AM   #13
dick_barton
My Country: Wales
Originally Posted by nbdy View Post
I got 323V DC
Was that voltage measured with the 5V connected to S/B using the 1K resistor.
Old 10-20-2019, 07:43 AM   #14
dick_barton
My Country: Wales
With your meter set to DC volts and the black meter lead connected to Pin5 (or 6,7,8 which are all connected together) of IC901 and the Red meter lead connected to the cathode of D904 when S/B is connected to 5V
Old 10-20-2019, 09:02 AM   #15
nbdy
My Country: Croatia
@dick_barton should the ENA also be connected to 5V ???
I got 440V between IC901 (5,6,7,8) and cathode of ZD904, without ENA connected only S/B with 1k to 5V ...
Yes the 325V is with the 5V to S/B with 1k ohm connected on the 100 uF/450V ...
Old 10-20-2019, 09:05 AM   #16
dick_barton
My Country: Wales
Yes both S/B and ENA with mainboard disconnected from power supply.
Old 10-20-2019, 09:18 AM   #17
nbdy
My Country: Croatia
with ENA and S/B to 5V i got 500V for 1-2 sec then a drop to 327V ...
On IC901 and ZD904 ..
Old 10-20-2019, 09:27 AM   #18
dick_barton
My Country: Wales
I got 440V between IC901 (5,6,7,8) and cathode of ZD904, without ENA connected only S/B with 1k to 5V ... ...
Not ZD904 but the diode D904 close to ZD904
Old 10-20-2019, 09:42 AM   #19
nbdy
My Country: Croatia
10,80v
Old 10-20-2019, 10:09 AM   #20
dick_barton
My Country: Wales
That voltage appears low. Can you check capacitor C912 (47uF, 50V)
