Old 10-17-2019, 11:34 AM   #1
rtstorm
rtstorm's Avatar
City & State: Croatia, Osijek
My Country: Croatia
Line Voltage: 230V 50Hz
Default VESTEL 17IPS71 - Quadro TV
Hello, i have this PSU 17IPS71 that have no other voltages except 12V on CN4 connector. I found that this board have many faults and i read this threadbut did not find any help.
What i try to do:
replace U202 (FAN6300)
replace LED driver (MP3394)
All caps look ok. I check all diodes and they are ok. On D22, D24 and D26 i have 12V.
On D11, D13 and D15 i got 30V.
On D27 i have 30V on bot sides (the diode is ok, not shorted)
So on output connector (CN4) i only get 12V no 5V.
Also on IR i get 3.3V (no 5V)
...the quieter you become the more you are able to hear...
rtstorm is offline   Reply With Quote
Old 10-17-2019, 12:49 PM   #2
R_J
City & State: ☻
My Country: Canada
Default Re: VESTEL 17IPS71 - Quadro TV
It very likely the board supplies 12v standby and not 5 volts, the lower voltages are likely supplied by regulators on the main board, and many IR work on 3v, These vestel schematics contains many circuits that may not be populated on the actual board.
What is the problem with the tv?
R_J is offline   Reply With Quote
Old 10-17-2019, 12:50 PM   #3
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Looking at the front of the psu there is no Q1 (BC377) fitted so no +5V_STBY
The IR may be a regulated voltage on the mainboard to provide 3.3V which may well be correct
dick_barton is offline   Reply With Quote
Old 10-17-2019, 01:43 PM   #4
rtstorm
rtstorm's Avatar
My Country: Croatia
Sorry guys, these pictures are not actual PSU (i download them on internet). But yes, the Q1 is not populatet on my board also.
This is the real pictures.
The problem is it wont start, no LED blink or nothing.
Old 10-18-2019, 11:23 AM   #5
arizanotlari
City & State: Diyarbakir
My Country: Turkiye
Line Voltage: 220VAC 50Hz
Hello.
Power board is working good. 5V is optional. Forget 5V and check mother board convertors.
What is mb name?
Arıza Notları
arizanotlari is offline   Reply With Quote
Old 10-18-2019, 11:57 AM   #6
rtstorm
rtstorm's Avatar
My Country: Croatia
hello, the MB name is 17MB82S
here is the picture
Old 10-18-2019, 12:00 PM   #7
rtstorm
rtstorm's Avatar
My Country: Croatia
edit: attach pics
Old 10-18-2019, 12:07 PM   #8
arizanotlari
My Country: Turkiye
re-program u12.
Old 10-18-2019, 12:23 PM   #9
rtstorm
rtstorm's Avatar
My Country: Croatia
Only U12? Or i need to reprogram U10 also? Where can i find file to flash?
I have TL866 Programmer
Old 10-18-2019, 12:41 PM   #10
arizanotlari
My Country: Turkiye
Visit Eeprom dump thread.
Or my little site https://www.arizanotlari.com/17mb82-...zilimlari.html
Rewrite only u12. If standby comes download 17mb82s panelsiz yazilim from my (little) site and install usb firmware to tv.
Old 10-18-2019, 02:27 PM   #11
rtstorm
rtstorm's Avatar
My Country: Croatia
I try to falsh U12 with 17MB82-1A flash but still no boot up. My panel is ves315wndb-2d-n02.
On my IR i have 5V :-)
Old 10-18-2019, 02:48 PM   #12
arizanotlari
My Country: Turkiye
Try this dump.
https://yadi.sk/d/-VD6Ga55GtzBMQ
Old 10-18-2019, 02:49 PM   #13
arizanotlari
My Country: Turkiye
Q61 is burning?
Old 10-18-2019, 07:35 PM   #14
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I am thinking the mediatec IC bad.
Old 10-20-2019, 10:22 AM   #15
rtstorm
rtstorm's Avatar
My Country: Croatia
i try the arizanotlari dump .bin files but still no change. The Q61 is not burning i did some solderin on it so it look like burning.
I try to heat the MediaTec IC and i got red light, but that is it. When i unplus and plug in back, again no red light.
