Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 10-15-2019, 06:34 AM   #1
davg
davg's Avatar
City & State: NL
My Country: Canada
Line Voltage: 120VAC 60 HZ
Default Replacing dvd with second hard drive
I am using a Toshiba portege a600 and installed a hard drive tray and hdd now the computer is giving me a cd rom error and is not recognizing the drive immediately but will pick it up in time until i shut down then I have to wait for it to recognize it again. Is there something I need to change in the bios
davg is offline   Reply With Quote
Old 10-15-2019, 07:26 AM   #2
diif
City & State: Midlands
My Country: England
Default Re: Replacing dvd with second hard drive
It sounds like it.
diif is offline   Reply With Quote
Old 10-15-2019, 12:10 PM   #3
davg
davg's Avatar
City & State: NL
My Country: Canada
Originally Posted by diif View Post
It sounds like it.
Any help on what? I did check the bios but don't see anything there related to the Rom other than in the boot priority and that is set to boot from HDD
Old 10-15-2019, 12:35 PM   #4
diif
My Country: England
SATA settings ?
Old 10-15-2019, 04:29 PM   #5
davg
davg's Avatar
City & State: NL
My Country: Canada
SATA settings ?
Nowhere in the bios settings to make changes to sata
Old 10-15-2019, 04:29 PM   #6
petehall347
City & State: worcester
My Country: United Kingdom
did you set it to slave ?
Old 10-16-2019, 04:58 AM   #7
stj
stj's Avatar
City & State: Europe
toshiba bioses are fucked, a lot of stuff is hidden or hard-coded.
i have had drive problems on several of them because of fixed ide settings
Old 10-16-2019, 05:30 AM   #8
davg
davg's Avatar
City & State: NL
My Country: Canada
this seems to be the case here not many options to make changes in the bios so was there a solution?
My drive works fine once it gets recognized as long as I don't shut down the laptop which is weird? Windows 10 I thought support plug and play
Old 10-16-2019, 12:28 PM   #9
stj
stj's Avatar
windows gets drive info from the bios.
interestingly Linux does not - i used to run an old motherboard with a 137gig drivesize limit,
i used a 40gig bootdrive amd serveral big drives for storage that the bios wouldnt see!!
maybe you can mod the bios - it depends on the version.
there are some editors floating around.
go ask on bios-mods.com
Old 10-17-2019, 05:39 AM   #10
davg
davg's Avatar
City & State: NL
My Country: Canada
What is most puzzling about this is the fact that it do eventually recognize the drive but about 5 min after powering up which almost suggest that the bios recognizes it as a CD Rom on POST and Windows recognize it as a drive once up and running. I tried this same setup in a Acer Laptop and that worked without an issue at all no need to change any settings bios or otherwise??
Old 10-17-2019, 08:53 AM   #11
stj
stj's Avatar
it's possible the drive is being picked up by a background task like smart checking.
