Old 10-07-2019, 01:04 PM   #1
Bibu
City & State: Italy
My Country: Italy
Default Philips 32pfh4309/88 restart problem
Hi to everybody, i have a problem with the tv in title.
The tv reboot it self when i give power to It.
Sometimes show the Philips logo and restart, sometimes only the backlight on and off.
There isn't Power led on.
I opened the tv and i don't see any blow caps or burn PCB.
I read in other discussion about an upgrade firmware with USB, i just try It without success.the TV restart before start the upgrade.
I think that in my case Is an hardware problem, what i can check and what are the problems for you?
Thanks to everybody
Bibu is offline   Reply With Quote
Old 10-07-2019, 09:00 PM   #2
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Default Re: Philips 32pfh4309/88 restart problem
can you post a straight shot, high resolution picture of your main board?
Old 10-07-2019, 09:14 PM   #3
yokoono
Last firmware
http://www.p4c.philips.com/cgi-bin/c...scy=DK&slg=AEN
yokoono is offline   Reply With Quote
Old 10-08-2019, 09:52 AM   #4
Bibu
City & State: Italy
My Country: Italy
Originally Posted by yokoono View Post
I Just try to update the firmware with USB,but doesn't work... The tv restart before start the procedure
Old 10-08-2019, 01:24 PM   #5
Bibu
City & State: Italy
My Country: Italy
This Is the main board
Old 10-08-2019, 07:55 PM   #6
CapLeaker
Leaking Member
CapLeaker's Avatar
My Country: Canada
Aaaah! I see a NAND IC (U405), where the Scart plug is. If you have a programmer like a TL866II or RT809H etc., read the NAND and save the file. Then erase the IC, followed by a blank check. Chances are there are bad blocks on that IC. Copy the content from the old NAND chip to a new NAND chip and reinstall it.
Old 10-08-2019, 09:17 PM   #7
yokoono
Procedure
Old 10-20-2019, 04:11 AM   #8
Bibu
City & State: Italy
My Country: Italy
I know the procedure, but i can't do it.because the TV restare before beginning the update
Old 10-20-2019, 09:39 AM   #9
yokoono
Turn on the TV and give it a cooling spray (freeze spray) on the nand memory.
