Go Back   Badcaps Forums > General Topics > General Computer & Tech Discussion
Old 09-28-2019, 03:13 AM   #1
IamPritesh
City & State: India
My Country: India
Default PC will only start when I clear CMOS through jumper
I have this dell desktop that runs only when I use jumper to clear cmos. Works fine until shutdown. TO start again, I have to start the process again.
What could be wrong and how to fix it ?
IamPritesh is offline   Reply With Quote
Old 09-28-2019, 04:36 AM   #2
Curious.George
Default Re: PC will only start when I clear CMOS through jumper
Does "runs only" mean that without the jumper in place, the computer SHUTS DOWN (i.e., powers itself off)? Or, does it just not boot into the OS properly unless the jumper is in place??
Curious.George is offline   Reply With Quote
Old 09-28-2019, 05:25 AM   #3
IamPritesh
City & State: India
My Country: India
IF the jumpers are removed or placed in default location it wont start at all on pressing the power button.
To power on the pc, I have to place the jumper in pin 1 and 2 to clear the bios.
Old 09-30-2019, 11:21 PM   #4
Huscarl17
City & State: Quincy IL USA
do you reload the defaults using the bios option before you reboot?
Make & model of the motherboard might help define the problem better
Huscarl17 is offline   Reply With Quote
Old 10-03-2019, 06:31 PM   #5
Curious.George
If your BIOS supports it, you may also want to "install factory defaults" and then "save current settings AS the default" -- in addition to just putting them in place (i.e., some machines have a "defaults" and a "factory defaults" -- which can be different, as a feature!)
Old 10-03-2019, 06:42 PM   #6
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
I'm a: Hobbyist Tech
Try taking everything off the main board including RAM, CPU, HDD, everything... then reinstall all components.
Old 10-04-2019, 04:00 AM   #7
piernov
Moderator
City & State: Valbonne, 06
My Country: France
Tried to update the BIOS?
OpenBoardview http://openboardview.org | IRC #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
