Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 09-26-2019, 12:34 PM   #1
davg
davg's Avatar
City & State: NL
My Country: Canada
Line Voltage: 120VAC 60 HZ
Default 12 volt DC Wiper motor hookup
I have a 12 volt wiper motor off a ford car that I was hoping to use to power the feed belt of a diy thickness sander but I am not sure how to hook it to a 12 volt battery. The wires on the connector are numbered with the following color
1- orange/purple
2 - white
3 -Green/Black
4 -
5 - Purple/White
6 - Black/Green
7 - Green/White
8 - Purple/White
9 - Green/Black
10 - orange/Blue
11 - purple/white
12 - Grey/brown
5,6,7and 8 are heavier gauge wire than 1,2,3,9,10,11 and 12. 4 is empty and both 5 and 8 are common
Tried a number of combinations but nothing worked Not at all sure how this should work any help greatly appreciated
File Type: jpg wipermotor 20190926_140548_7_bestshot.jpg (1,014.7 KB, 9 views)
davg is offline   Reply With Quote
Old 09-26-2019, 01:15 PM   #2
petehall347
City & State: worcester
My Country: United Kingdom
Default Re: 12 volt DC Wiper motor hookup
best bet is find the wiring diagram for the car and hope it shows switch connections .
Old 09-26-2019, 02:10 PM   #3
redwire
City & State: Alberta
My Country: Canada
12 wires? It will be easier to train a hamster to spin a wheel.
WS00000399 is from 2007-2011 Ford Focus. There was a recall for water getting in them. Ford seemed to go crazy with the designs.
Look for a Ford Focus wiring diagram, but I did not see any with so many wires. Unless it's from a minivan where the wipers park.
redwire is offline   Reply With Quote
Old 09-26-2019, 02:35 PM   #4
stj
stj's Avatar
City & State: Europe
you need to open it, it has switches in it to detect the end of travel and may even have them wired to reverse the motor.
you have to remove the limit switches and any type of cam that hits them and limits rotation.
Old 09-26-2019, 02:42 PM   #5
davg
davg's Avatar
City & State: NL
My Country: Canada
Correction wire 9 is (green and purple) not black. Tks redwire it is from a ford focus and maybe it doesn't work? I'll see what I can find in a wiring diagram at the local Ford service center, but they don't like sharing that kind of info?? Anyone know where I might find one on line? I did some searching but didn't find anything specific.
Old 09-26-2019, 02:51 PM   #6
stj
stj's Avatar
what year?
i have 2006 and 2010 manuals
Old 09-26-2019, 05:18 PM   #7
davg
davg's Avatar
City & State: NL
My Country: Canada
Originally Posted by stj View Post
what year?
Tks stj but I have no idea of the year just what popped up when I Googled part # WS00000399 it says 2007 - 2011 Ford Focus. I pulled it from a wreck in the scrap yard and didn't realize it was going to be so complicated.??
Old 09-26-2019, 06:35 PM   #8
petehall347
someone at FORScan forum might have diagrams
Old 09-26-2019, 06:40 PM   #9
Curious.George
Many auto parts stores have tools and documentation that they will make available to you (for free). Autozone, O'Reilley, Pep Boys, etc. No idea who does business north of the border, though...
They may even have a test fixture/harness that you could use to check the operation of the motor.
Curious.George is offline   Reply With Quote
Old 09-26-2019, 08:04 PM   #10
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
I do have a 99-05 Haynes manual for my Focus on the way this week. I'll let you know when I get it and see if it has anything detailed like that in there (though I doubt it.) I imagine the 2007-2011 Focus models shouldn't be that much more different that the first MK1 and MK2 Focus models, but who knows? With so much computerized crap in cars nowadays, it could be a completely different part design.
Old 09-27-2019, 05:40 AM   #11
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
I would take a volt meter and see which wire have a direct short will be your switches and ones that some resistance to them might the motor windings It might be high and low speed winding
There might be a park switch and what the other wires not sure of
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
Old 09-27-2019, 08:13 AM   #12
stj
stj's Avatar
just open it,
your intended use has no use for end-sensors or switches anyway.
Old 09-27-2019, 04:24 PM   #13
Curious.George
just open it,
There may be a connection to unswitched battery that ensures the wipers park even if the ignition is switched off "mid-action". And, another connection to the wiper control knob and SWITCHED battery (i.e., so the wipers keep running into "park" with ignition off but can't be turned on with ignition off).
Mitchell or Autodata should have the info needed (or, your local auto parts store).
Old 09-28-2019, 07:10 AM   #14
davg
davg's Avatar
City & State: NL
My Country: Canada
This is complicated I did open it up and yes there is a switch on a circuit board controlled by a magnet on the rotor and the circuit board has three contacts that feed into the motor which are the two speeds and ground. I can run the motor by putting 12 volts across these contacts but I can't find any wires in the wiring harness that will supply 12 volts directly to any of these contacts?? I could eliminate the circuit board??
Old 09-28-2019, 09:35 PM   #15
stj
stj's Avatar
yes, it's a 12v motor so rip the junk out.
Old 09-29-2019, 09:06 AM   #16
sam_sam_sam
If you are going to use as a sander motor let me make a subjection to you to maybe also use a current sensor meter and here is why
This motor was made for a windshield which does not have very much load on it but you going be using as a sander which the current load will very and if use for a long time you might find that the motor will get very warm to very hot and it might do this very fast depending on how much current load you are doing
Something like this
I have not bought from this seller
https://www.ebay.com/itm/DC-100V-100...53.m1438.l2649
I have bought from this seller
I bought two of them one was the right model the other one was not the right model
https://www.ebay.com/itm/DC-300V-50A...sAAOSwHGJcOJb4
Old 09-30-2019, 06:18 AM   #17
davg
davg's Avatar
City & State: NL
My Country: Canada
Something like this
Just using it to run the conveyer belt not the sanding drum not sure how much load that would place on the motor? Just what benefit would this device provide other than show what kind of loads the motor is being subjected to?
