Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Equipment Usage, Soldering, Techniques, and Reviews
Old 09-06-2019, 07:24 AM   #1
tmcw
City & State: Ireland
My Country: Ireland
Line Voltage: 240V AC, 50Hz
Default Multimeter Repair - continuity buzzer (RAPID 328 DMM)
I have one of these cheap multimeters, and when set to continuity/diode setting, and the probes touched together, the 20mm piezo makes a scratchy, muffled, weak noise, barely noticeable. The display does show the response, going from "1" to "0.00".
The piezo is ok, I transplanted it to a similar multimeter, and it makes a nice loud tone. I tried a couple of smaller piezos, the type pulled off old motherboards (12mm type), and it makes the same scratchy, muffled noise.
However, I did find a bigger piezo (about 22mm diamter), that I think was pulled off a UPS board, and when I try with this in place of the original piezo, it makes a nice loud noise. But whereas the other piezos are just a piezo, this one that works has some extra circuitry built in (picture 3).
So it looks like there is something wrong with the electronics going to the original piezo on the DMM board. Will the multimeter have a similar circuit to the 22mm piezo somewhere?
Is it possible to get a smaller piezo with a circuit inside it like the bigger 22mm piezo? I couldn't get the bigger piezo to fit the case, but a smaller 12mm piezo with a circuit built in could fit in one of the corners of the multimeter case, if there is such a thing.
Are there any other viable options?
tmcw is offline   Reply With Quote
Old 09-06-2019, 09:08 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Multimeter Repair - continuity buzzer (RAPID 328 DMM)
your problem is unlikely the piezo,
show the other side of the board.
Old 09-07-2019, 08:46 AM   #3
tmcw
My Country: Ireland
Yeah, those piezos would probably survive a bombing, and it does test ok in another multimeter.
Attached are a couple of photos of the other side. The center of the piezo (red wire in photos in first post) is connected to the small pad above component Q4.
Old 09-07-2019, 12:34 PM   #4
redwire
City & State: Alberta
My Country: Canada
Some piezo drive circuits are done wrong.
A piezo is a capacitive load and needs push-pull (source and sink) current to move. If you drive one with an open-collector transistor Q4 (charge but no discharge path), the piezo will be way quiet.
The fix is putting a resistor like 330R-1k in parallel (with disk) so the piezo's capacitance gets a way to discharge. I would try that.
Changing to a piezo buzzer (built-in oscillator) is a last resort.
redwire is offline   Reply With Quote
Old 09-07-2019, 03:24 PM   #5
stj
stj's Avatar
well you could trace the drive circuit before the transistor,
but to be honest it's such a low spec mastech meter that you may as well get an ANENG 8009 for 10 or something.
Old 09-13-2019, 07:30 PM   #6
momaka
master hoarder
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
I think scratchy piezo sound is typically caused by either:
a) low/dying battery
b) dirty contacts in the rotary switch
... at least that was the case for all of my multimeters.
