Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 07-28-2019, 05:42 AM   #1
maxslo
City & State: Ljubljana
My Country: Slovenia
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Question lighting circuit modification
Hello, it's been a long time since my last post and i'm here again seeking advice from more experienced guys
I have a night light that had it's incandescent 10W bulb die recently, and i've bought a 2.3W LED to replace it, but i've immediately noticed that when it should turn on, instead it's flickering. There was only ~130ish Volt AC across the leads for the bulb so i've thought that this must be some sort of dimming mechanism for the incandescent bulb. I've since taken it apart and drawn a schematics to the best of my ability.
No here is the question. What would be the easiest thing to change in the circuit, to maintain the night/light sensing and be able to run the LED off it properly?
Here's the schematic:
Thanks in advance for any input
maxslo is offline   Reply With Quote
Old 07-28-2019, 02:23 PM   #2
stj
stj's Avatar
City & State: Europe
Default Re: lighting circuit modification
you need a resistor in parallel with the led lamp.
i dont know what value, but that circuit uses the lamp as a source of power to the light sensor.
led lights are not resistive, they are inductive.
Old 07-28-2019, 02:32 PM   #3
maxslo
Ok thanks, i can measure the resistance across LED's circuit, would that help in determining the required resistance?
Old 07-28-2019, 02:46 PM   #4
redwire
City & State: Alberta
My Country: Canada
MCR100 is an SCR, so when it is turned on it outputs only 1/2 wave pulsing DC to the light bulb.
Your LED lamp probably does not like this and may not work if it uses a capacitive dropper- then it really wants AC, not pulsing DC coming in.
If you post a pic of the LED lamp's circuit, you can figure it out if it will work.
redwire is offline   Reply With Quote
Old 07-28-2019, 02:55 PM   #5
maxslo
Ok i'll check if i can take it apart without breaking it.
Just a thought would it be possibile to change the MCR100 out for another element (if it exists), that would output entire sine wave to the lamp.
Edit: I have been able to remove the plastic cover over the LED's, but the circuitry is inside the bulb's base and is not accessible unless i destroy the base :/
Old 07-28-2019, 03:35 PM   #6
redwire
My Country: Canada
I did find the same night light circuit but using a CR02AM-8A triac which should give full-wave to the lamp. It is hard to find very sensitive gate (100uA) thyristors.
File Type: jpg automatic-light-dimmer-circuit_triac.jpg (31.4 KB, 20 views)
Old 07-28-2019, 06:27 PM   #7
eccerr0r
Solder Sloth
eccerr0r's Avatar
City & State: CO
Line Voltage: 120VAC 60Hz
Duplicate the circuit in reverse ...
eccerr0r is offline   Reply With Quote
Old 07-29-2019, 12:38 AM   #8
maxslo
Thanks, this might be just what i was looking for, i'm just a bit confused about the information i read from the spec sheeet.
namely this:
why does it say half sine wave?
Old 07-29-2019, 04:26 PM   #9
redwire
My Country: Canada
The I2t (amp squared seconds) value is based on the time for a fuse blowing 10-16msec, or 1/2 cycle.
Old 07-29-2019, 06:59 PM   #10
petehall347
City & State: worcester
My Country: United Kingdom
i might add a capacitor if led flickers too much
Old 07-30-2019, 12:15 PM   #11
maxslo
Ok thanks, i've ordered the relay. I'll update the thread once i install it
Old 07-30-2019, 03:47 PM   #12
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Relay? The schematic on your post 1 using the SCR which means the 10W lamp is only be using 5W of power due to half wave action of the SCR, so when you use your meter the Voltage you test is the pulsing DC so it will not show 230VAC.
Old 07-30-2019, 08:15 PM   #13
budm
budm's Avatar
Half wave recitification.
https://www.physics-and-radio-electr...rectifier.html
Old 08-01-2019, 10:54 PM   #14
maybe
City & State: Beijing,China
My Country: China
Your project remind me a electronic project I have tried before about Electric Car Lamp, it's here: https://3celectrons.com/2019/07/25/d...-power-supply/
maybe is offline   Reply With Quote
Old 08-02-2019, 12:29 AM   #15
redwire
My Country: Canada
This is a night light- how does it remind you of a bicycle light? Nothing in common unless you are trying to sell something.
Old 09-16-2019, 12:57 AM   #16
maxslo
Sorry my bad, I meant the triac.. I've just seen that it was rejected to ship out of china due to security issue??? never had that happen before, so i've just ordered one from UK to avoid extra 1-2 months of wait time
I'll post back with results when i receive and intall it.
Old 10-05-2019, 12:53 PM   #17
maxslo
The triac arrived an i've installed it. The light now doesn't flicker anymore, however the light also doesn't turn off when it's daytime xD.. i'll give it another go tomorrow
