Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Desktop Motherboards, Graphics Cards, and PC Peripherals
Thread Tools Display Modes
Old 09-13-2009, 01:58 PM   #1
krazykev64
Default Bad Biostar
I recently had to cure a problem on a computer for an old lady. she said her computer was freezing up for no reason. i could see after a while that her mouse and keyboard become unusable. this happened a few times so i decided to re install windows.. this is when the fun started. i made 3 attempts and everytime the thing would do exactly the same during installing windows. the mouse and keyboard would freeze. even a different windows disc made no difference not even a different version of windows. i then decided to take off the side cover. it did not take long to see what was wrong. there must have been around 20 or more leaking capacitors. this was the worst bad cap board i had seen. i decided it would be pointless re capping the board as she had very little stored on the computer and it is mainly used for light gaming type work. a new socket A board is still available but the problem is that the biostar board uses pc133 memory and not ddr. it would work out cheaper to buy a modern board with suitable cpu and memory. at least she will end up with more than the pultry 128mb of ram and have a much more powerful system overall. i will have to post pics when i have done the job. i think every cap has gone
krazykev64 is offline   Reply With Quote
Old 09-25-2009, 05:41 AM   #2
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Professional Tech
Default Re: Bad Biostar
I agree, probably not worth repairing. 128MB of RAM is insufficient for modern-day tasks and a board old enough to use SD RAM is brobably only worth about $20 and it would cost at least that to re-cap if there are that many bad caps. Out of curiosity, what brand were the caps, and what model was the mobo?
__________________
c_hegge is offline   Reply With Quote
Old 09-25-2009, 09:11 PM   #3
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
My Country: USA
Line Voltage: 120VAC 60Hz
i would find a socket a board and get ddr ram. ddr is cheaper per mb than sdram, and is faster. biostar+'lytic caps= bad caps.
__________________
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 09-26-2009, 02:57 PM   #4
krazykev64
I now have this motherboard on the bench. there is a total of 18 caps that are bulging and/or leaking brown gunge. it is NOT a Biostar board. to be honest i dont know what make it is. the handbook says ''motherboard'' That is a brand i have never heard of but it is highly likely that it is a clone. it has a SIS 730s chipset. the model is 830CH. It was purchased in 2002 so i suppose 7 years is quite good. every single cap is made by ''GSC'' I have posted a photo showing every blown cap. first signs of trouble was a freezing keyboard and mouse and when i went to install windows it refused to install and kept blue screening
Old 09-26-2009, 04:44 PM   #5
Newbie2
Newbie2's Avatar
City & State: Halifax, NS
My Country: Canada
I'm a: Complete Noob!
GSC is an infamous crap capacitor brand. Since this motherboard can still POST, replacing those failed GSC capacitors with suitable replacements of higher quality will fix the problems that you are encountering with this motherboard.
__________________
My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
Newbie2 is offline   Reply With Quote
Old 09-26-2009, 05:33 PM   #6
krazykev64
i think i have found out the make of the motherboard. it seems like it could be a JETWAY. Whatever the make its a load of crap and will go in the bin. it was only around 30 anyway. its been replaced with a ASROCK ALive NF7G-GLAN
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
