Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Laptops, Portable, and Mobile Devices
Thread Tools Display Modes
Old 10-16-2019, 03:03 AM   #1
mnciks11
City & State: durban
My Country: south Africa
I'm a: Knowledge Seeker
Default MacBook model A1466 EMC 3178 Backlight problem
My lovely fellows, I have MacBook A1466 with no backlight, checked the fuse it working, it got 12v on both sides, the output capacitors have 8.6v, is that okay, I have no backlight on the screen please help my, PIN number 3 and 4 on the screen connector are PPVOUT SW LCDBKLT both are connected and have 8.6v
Please guys kindly find attached photos and boardview photos
File Type: jpg 0776BD5B-9834-4575-8CD0-21BCCA735D13.jpg (258.4 KB, 15 views)
File Type: jpg 30EFC287-4D63-4BB6-B6F0-3DD1EE7A4297.jpg (298.2 KB, 10 views)
File Type: jpg DB1DC868-79A4-4B65-A464-0F5070242FC1.jpg (241.2 KB, 6 views)
File Type: jpg B9CCBE64-5C5E-42B9-B320-70B7F1D4ED06.jpg (424.5 KB, 6 views)
mnciks11 is offline   Reply With Quote
Old 10-16-2019, 07:11 AM   #2
dilip.pawar31
City & State: INDIA
My Country: india
Default Re: MacBook model A1466 EMC 3178 Backlight problem
ROSSMacbook Air no backlight troubleshooting
When troubleshooting backlight circuit, the output voltage is important. Different voltages tell you different things.
On an air, 39-49v means that the backlight boost circuit is working, but there is no load - aka, it doesn't "See" the light of the screen. Once there is a load on the circuit, like the light of the screen, the voltage will go down. This can be caused by bad LCD connector, bad LCD cable, LCD backlight cable being plugged in upside down(most common one), bad LED strip in the screen.
25-27v means backlight is working and we are just blind.
18-20v means that the boost circuit is partially working. This is usually missing BKL_PWM signal, or bad LED driver. BKL_PWM sets the brightness on the screen. If the LED driver is working but PWM is too low, there will be voltage boost, but it will be just below the threshold required to light the screen. Sometimes BKL_PWM is missing because the brightness down key is stuck down(liquid on keyboard), sometimes this is missing because the machine is fucked(you can just send pp3v3_s0 to the bkl_pwm line if it is missing to tell it to stay on at full brightness), sometimes the LED driver is shorting it to ground.
If you have 8.5v on backlight, that means no boosting is occurring. This can be bad LED driver, this can be feedback line from backlight output to ball A5 of the LED driver for feedback being destroyed(VERY COMMON). Also BKL_EN voltage divider being bad - you need at least 2.7v on BKL_EN or you get no boosting and wind up with 8.5v on backlight, which is just PPBUS_G3H being passed through the circuit.
If you have anything below 8.5v it could be a number of things. Here, if we have 0 volts, the first thing to determine is if we can actually see an IMAGE on the screen. If the computer does not detect the screen properly, and does not display an image, our issue is image/screen recognition, not backlight. The computer is smarter than an iPad, it won't send backlight out if the screen is fucked. So do you see a picture?
If you do have 0v, it is often a short to ground on the line, or dead fuse, or blown via/trace somewhere in the boost circuit. See on the top of my picture where L9701 goes to D9701 which goes to output? If there is a break anywhere in that line, you get 0v on output, OR soemthing like 1.2v, or 0.125v, or some really low shit because the via is broken and making intermittent contact.
Either way, in order to start properly troubleshooting what is going on, we need way more information. I have also attached pictures of some common backlight faults. Again, don't make fun of me and microsoft paint, it's all I got it works for GradeAUnderA!!
dilip.pawar31 is offline   Reply With Quote
Old 10-16-2019, 03:26 PM   #3
piernov
Moderator
City & State: Valbonne, 06
My Country: France
The feedback via typically gets eaten away after liquid damage. Cannot see much on the picture, but something is going on there.
File Type: jpg 30EFC287-4D63-4BB6-B6F0-3DD1EE7A4297.jpg (382.2 KB, 12 views)
__________________
OpenBoardview http://openboardview.org | IRC #openboardview@irc.freenode.net
piernov is offline   Reply With Quote
Old 10-19-2019, 03:26 PM   #4
mnciks11
Quote:
Originally Posted by dilip.pawar31 View Post
rossmacbook air no backlight troubleshooting
when troubleshooting backlight circuit, the output voltage is important. Different voltages tell you different things.
On an air, 39-49v means that the backlight boost circuit is working, but there is no load - aka, it doesn't "see" the light of the screen. Once there is a load on the circuit, like the light of the screen, the voltage will go down. This can be caused by bad lcd connector, bad lcd cable, lcd backlight cable being plugged in upside down(most common one), bad led strip in the screen.
18-20v means that the boost circuit is partially working. This is usually missing bkl_pwm signal, or bad led driver. Bkl_pwm sets the brightness on the screen. If the led driver is working but pwm is too low, there will be voltage boost, but it will be just below the threshold required to light the screen. Sometimes bkl_pwm is missing because the brightness down key is stuck down(liquid on keyboard), sometimes this is missing because the machine is fucked(you can just send pp3v3_s0 to the bkl_pwm line if it is missing to tell it to stay on at full brightness), sometimes the led driver is shorting it to ground.
If you have 8.5v on backlight, that means no boosting is occurring. This can be bad led driver, this can be feedback line from backlight output to ball a5 of the led driver for feedback being destroyed(very common). Also bkl_en voltage divider being bad - you need at least 2.7v on bkl_en or you get no boosting and wind up with 8.5v on backlight, which is just ppbus_g3h being passed through the circuit.
If you have anything below 8.5v it could be a number of things. Here, if we have 0 volts, the first thing to determine is if we can actually see an image on the screen. If the computer does not detect the screen properly, and does not display an image, our issue is image/screen recognition, not backlight. The computer is smarter than an ipad, it won't send backlight out if the screen is fucked. So do you see a picture?
If you do have 0v, it is often a short to ground on the line, or dead fuse, or blown via/trace somewhere in the boost circuit. See on the top of my picture where l9701 goes to d9701 which goes to output? If there is a break anywhere in that line, you get 0v on output, or soemthing like 1.2v, or 0.125v, or some really low shit because the via is broken and making intermittent contact.
Either way, in order to start properly troubleshooting what is going on, we need way more information. I have also attached pictures of some common backlight faults. Again, don't make fun of me and microsoft paint, it's all i got it works for gradeaundera!!
the feedback was not touching the other side of the board, thank you so much
Old 10-19-2019, 03:27 PM   #5
mnciks11
Smile Re: MacBook model A1466 EMC 3178 Backlight problem
Quote:
Originally Posted by piernov View Post
the feedback via typically gets eaten away after liquid damage. Cannot see much on the picture, but something is going on there.
you always nail it, you are the best man
thanks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
