Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Computer Displays
Thread Tools Display Modes
Old 01-24-2018, 02:04 PM   #1
Behemot
Behemot's Avatar
City & State: Prague, 504'52.22"N, 1423'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
I'm a: Knowledge Seeker
Default Acer B326HUL power supply dead
Display only blinks and than stays dead. Check open the PSU revealed it is dead.
There are three output rails: winding to feed the TEA1791T synchronnous rectification controller (this thing has no connection with primary side!), the output for the rectification transistor - this rail feeds the signal board, and than backlight rail.
Seems like the unit only pumps few cycles to the secondary so voltage rises a bit and than falls down as the caps discharge. I have about 15.5 V on a small cap on the primary auxiliary rail just after the diode which slowly falls, pumps again to 15.5 V and that repeats.
There is however oscillating voltage between like 18 and 19.6 V on the cap directly in front of the primary common PFC/PWM controller. Do not think this is normal condition. Cannot identify the controller right now, it has layer of lackquer, gonna have to try removing it.
I do see only 320V on the input cap though, there is no spike suggesting the PFC would be turning on, so maybe the problem lays in here?
__________________
Behemot is offline   Reply With Quote
Old 01-25-2018, 06:30 AM   #2
Behemot
Behemot's Avatar
My Country: CZ
Default Re: Acer B326HUL power supply dead
It's very difficult to read anything in here but it seems like the PFC/quasi-resonant flyback controller is NXP, possibly TEA1751T. According to the datasheet, the startup voltage is 21-23 V so when it's at 18-19.6 that's too low.
The path goes from the auxiliary winding on primary side through inductor to an SMD diode, capacitor and than there is "K415 C200" TO-92 bipolar transistor. The 15V feed leads to its collector, the oscillating 18-19.6V output is on its emitter. Collector and base has 1002 SMD resistor in between and base is also connected through an SMD zener to return.
So it seems like some amplifier with zener feedback? And this is to feed the Vcc of the controller.
Old 05-09-2018, 07:04 AM   #3
fred41
I also have a dead power board, did you manage to find some datasheet, schematics, wathever informations about this card? Thanks
fred41 is offline   Reply With Quote
Old 05-09-2018, 10:18 AM   #4
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
If we can see some good clear pictures of the boards and how they are connected together, that will be a good starting point.
__________________
budm is offline   Reply With Quote
Old 05-10-2018, 07:57 PM   #5
fred41
If you need more detailled pictures or anything else, ask.
Old 05-13-2018, 11:25 AM   #6
fred41
Quote:
Is it useful?
Old 05-13-2018, 05:46 PM   #7
budm
budm's Avatar
My Country: USA
SO, what Voltages do you have on that white connector of the power supply board that goes to the logic/main board?
Old 05-15-2018, 04:43 AM   #8
fred41
Hi, Budm
Thanks for your answer
I have no light on the front power push button.
I tested the general 220v power switch on the back, and the fuse.
And to answer your question, I have 0v on each wire on the white connector, with the board plugged or unplugged:
https://www.youtube.com/watch?v=8uVT8g2OchQ
I have 335Vdc arriving to the "120F / 450V" capacitor, and I unsoldered it and tested it too:
https://www.youtube.com/watch?v=IL7uwboCR70
Hope I done everything right, and made myself understood, English is not my first language.
Old 05-15-2018, 11:31 AM   #9
budm
budm's Avatar
My Country: USA
In your picture #2 on the bottom left, there is an IC (18-PIN?) there, can you read the P/N?
Old 05-16-2018, 10:14 AM   #10
fred41
Hi, I tried to take pictures and read the part references
n1 : NXP TEA1751T CDX12104 TXD14241
n2 : MPS1431 MP3398 E44H2168A
n3 : unreadable, but seems to be the same as n2
thanks
Old 05-16-2018, 11:14 AM   #11
budm
budm's Avatar
My Country: USA
thanks
OK, #1 is the one we need to find out if it has DC Voltage between VCC pin and Gnd for it run or not. Please see the spec sheet.
NOTES: You will be working in the HOT DEADLY side of the circuit so do not touch ANYTHING with your hands or body, you should at least plug the monitor into GFCI outlet.
Old 05-16-2018, 12:24 PM   #12
fred41
Thanks a loot for your answer, but I'm not sure what GFCI means exactly, is it an outlet with ground? I live in France , and this is the default wall outlet we have :
Am I right for where to test?
Old 05-16-2018, 12:42 PM   #13
Andrew F. Ali
Andrew F. Ali's Avatar
City & State: Point Fortin
My Country: Trinidad & Tobago
Line Voltage: 125VAC 60Hz
GFCI means Ground Fault Circuit Interrupter. This is an electrical outlet with Reset button and a Test button on it that should a shock hazard be detected it would switch the supply to the receptacle OFF.
Andrew F. Ali is offline   Reply With Quote
Old 05-16-2018, 12:47 PM   #14
fred41
Quote:
Like this?
I have one
Old 05-16-2018, 01:06 PM   #15
Andrew F. Ali
This is how our electrical GFCI outlets look like. The RED button is the RESET and the BLACK button is the TEST. So is a fault is detected the RED button pops up and disconnects the supply and to reset is to just push it back in. When the Test button is depressed the RESET button pops up and so we know the system is working.
Old 05-16-2018, 02:32 PM   #16
budm
budm's Avatar
My Country: USA
EURO GFCI outlet:
http://internationalconfig.com/icc6.asp?item=4721-10HG2
Old 05-16-2018, 02:36 PM   #17
budm
budm's Avatar
My Country: USA
That is correct pin out for TEA1751:
Pin 1 = VCC
Pin 2 = GND
Old 05-16-2018, 06:29 PM   #18
Andrew F. Ali
Thanks budm
Old 05-17-2018, 01:30 PM   #19
fred41
I measured 18.5Vdc - 19Vdc
And I didn't blew up the house, nor I burned myself...
Thanks everyone
Old 04-15-2019, 10:52 AM   #20
the.norbulus
City & State: Melbourne
My Country: Australia
Hi fred41, you and I seem to be in a similar fix. I have a Benq 32" with a dead psu and the board is similar to yours. Also the fault on mine seems to be in the same general area as yours (around the TEA1751)
Could you please tell me the value of the resistor on your board between pin 16 on the TEA1751 and the transformer? Mine has burnt out.
Have you had any luck getting yours going?
Here's my thread: https://www.badcaps.net/forum/showth...830#post890830
the.norbulus is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
