Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 08-11-2018, 01:30 AM   #1
ngth82
City & State: Vancouver, WA
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Xbox One drive part - white plastic arm in DG-6M2S-01B
Hi all -
I'm trying to source this white plastic arm from a DG-6M2S-01B Xbox One optical drive... does anyone know where to get it? I searched eBay and haven't been able to find one.
When these break, the only option that I have so far is to buy an entirely new drive (and the end customer ends up paying way too much for something that I'm hoping can be a cheap fix).
Thanks in advance!
-Thomas
__________________
-Thomas
Hardware Engineer by day, consumer electronics fixer at night
ngth82 is offline   Reply With Quote
Old 08-11-2018, 06:22 AM   #2
stj
stj's Avatar
City & State: Europe
My Country: some shithole run by Israeli agents
I'm a: Professional Tech
Default Re: Xbox One drive part - white plastic arm in DG-6M2S-01B
if they break a lot then try AliExpress.
the chinese will probably copy them.
stj is offline   Reply With Quote
Old 08-21-2018, 04:17 AM   #3
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Hobbyist Tech
If that white plastic is made of ABS or PC plastic, you can try gluing it back with PVC glue (or any other glue that works on ABS plastic). The glued joint will be just as strong as the original plastic (if not stronger, if you over-apply the glue) as ABS, PC, and PVC plastic get dissolved in PVC/ABS glue. When the glue dries, the glued joint has the same properties as the original plastic.
That said, if the drive has space, you can also add a bit of strengthening plastic pieces on that part to make it stronger. Just make sure to use ABS, PC, or PVC plastic.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
