Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 05-12-2009, 07:42 PM   #41
MegaOne302
MegaOne302's Avatar
City & State: Brooklyn, NY
Thumbs up Re: Intel D865GLC AA C28906-410 Recap
I’m just being a smart ass; it’s been so long since I ordered anything from them that I truly forgot they even existed.
Thanks for the reminder, I'll order all the needed 8mm and 10mm sp-caps from them if they have.
Thank you sooooooo much dude...
Does an idiot make a sound if no one’s there to hear them talk?
MegaOne302 is offline   Reply With Quote
Old 05-12-2009, 07:56 PM   #42
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Default Re: Intel D865GLC AA C28906-410 Recap
Oh god! Don't say dude to him. Geeze, the last guy....
Well, let's just say it wasn't pretty. hehehehehee
>>why didn’t I find them in my Mouser cat...<<
ROFL!
The new on is over 2-1/2" thick and just about 4 pounds.
Toast
Toasty is offline   Reply With Quote
Old 05-12-2009, 07:58 PM   #43
MegaOne302
MegaOne302's Avatar
lol
I take the dude thing back.
Thank you Sir...
Old 05-12-2009, 08:43 PM   #44
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Nah, this is Tuesday.
Dude is okay on Tuesday.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 05-12-2009, 08:44 PM   #45
MegaOne302
MegaOne302's Avatar
You're the best...
Old 05-13-2009, 04:45 PM   #46
MegaOne302
MegaOne302's Avatar
That’s odd…
Looks like they don’t make 16v 1200uf sp-caps. The closest match I find is 16v 1000uf; is it ok to use those for the 12v line?
Looks like anything over 1000uf can use an low e-cap.
Old 05-13-2009, 05:13 PM   #47
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
I'm guessing the 1200uF 16v are the VRM input caps. ???
uF isn't so important there as ESR.
Assuming 3 or 4 VRM input caps. it's common practice when Switching from lytics to sp in VRM input to use 330uF-16v or 470uF-16v polys.
That's also what you'll usually see on boards that come with polys there originally.
My preference is 470uF 16v or to use the Intel-Dell method below.
A number of Intel boards built for Dell mix one lytic with two polys in VRM input.
Since all 3 [or 4] are in parallel that gives the best of both worlds.
- Very low ESR and uF not so low.
For those caps the ESR keeps the noise out and the uF smooths out PSU voltage fluctuations from load changes and start-up/shutdown ops.
Using one 16v 1800uF [or up] lytic there isn't a bad idea just in case the mobo some day gets attached to a crappy PSU that lets voltage wander around.
Old 05-13-2009, 06:29 PM   #48
MegaOne302
MegaOne302's Avatar
So there are two VRM banks, one for the 2.5v for the Vcore ESR filtering and one 16v bank for gross ESR filtering of the PSU.
I still don't fully understand what the uf value means; is it the repeated ripple value the cap can handle?
Old 05-13-2009, 08:13 PM   #49
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
uF is capacitance in Micro-Farads
The Ripple rating is how much Ripple Current can pass through the cap without it overheating. It is similar to the Watts rating on a resistor.
No.
Not two banks.
Power-In side and Power-Out side.
See PIC. [Only one cap shown in each spot for simplicity.]
VID tells Controller what Vcore voltage should be on CPU.
Controller Senses the Vcore voltage.
Controller turns MOSFETs on-off [very fast] to adjust voltage.
VRM-IN caps give MOSFETs clean power by filtering out noise from PSU.
VRM-OUT caps give CPU clean power by filtering out on-off pulses from MOSFETs.
Old 05-13-2009, 09:15 PM   #50
MegaOne302
MegaOne302's Avatar
Double filtering for the CPU I see.
Ok, so the two cap banks act as filters but in kind of different ways.
The VRM-In bank filters the 12v line-in, protecting the MOSFET-in from line noise and surges.
Then
The VRM-out bank filters the MOSFET-out, protecting\stabilizing the voltage to the Vcore from a kind of switching noise.
Did I get everything?
And I thought DC current was easer tamed…
Really nice drawing BTW…
Old 05-13-2009, 09:34 PM   #51
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
You're getting it now!!
MOSFETs are basically switches that turn on-off very fast.
They aren't on-off at the same time [or length of time].
Controller adjusts their on-off 'duty cycles' to get the desired voltage for Vcore.
The switching action of the MOSFETs causes pulses that the VRM-OUT caps filter out.
Old 05-13-2009, 09:36 PM   #52
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
There aren't any modern processors with a Vcore over 2 volts so 2.5v rated caps are just fine there.
Old 05-13-2009, 09:43 PM   #53
MegaOne302
MegaOne302's Avatar
Yes, I was thinking the same. The Vcore was around 1.34v
Tanks for today’s lesson.
Old 05-16-2009, 05:27 PM   #54
MegaOne302
MegaOne302's Avatar
Lightbulb Re: Intel D865GLC AA C28906-410 Recap
Hi PC,
Is there any way to view the capacitance and ripples in a circuit with the cap left in? I have a feeling many motherboard caps uf are overshot to get the ESR low.
Thanks,
Joe
Old 05-16-2009, 11:07 PM   #55
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
You'd need an O'scope to see ripple.
Old 05-16-2009, 11:10 PM   #56
MegaOne302
MegaOne302's Avatar
Can one be easily built or cheaply bought from eBay? If so, can you recommend a very basic one?
Old 05-17-2009, 02:19 AM   #57
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Build an Oscilloscope? . Not likely.
You can find them on ebay and if you're patient come in under $200 and -sometimes- a lot less [$100 ??] but you need to be careful about getting one that actually works. - LOTs of busted ones for sale on eBay.
Ideally you'll need a Digital Storage Oscilloscope [DSO] or at least a Storage O'scope vs an Analog. Analog is best used for signals that repeat over and over without changing and noise doesn't do that. A Storage scope will capture a moment in time and display it vs changing on every refresh of the screen as an Analog scope does.
A 20MHz Bandwidth as adequate for SMPS noise but 60-100MHz are fairly cheap and you can do much more with them.
There are also USB versions that display on a PC that are adequate and it's kind of handy to be able to save the image on the PC which most regular scopes can't do and most that do need a bunch of extra gadgets.
I have an old Mainframe Tektronics with plug-in bays that lets me swap plug-ins to reconfigure the scope for different things. With the right plug-ins it can be bumped up to 1Ghz or even changed into a Spectrum Analyzer. I presently have 6 plug-ins for it and currently it's good to 400 MHz. The down sides are it's BIG and HEAVY and those plug-ins need a bunch of room in a clean static free storage space.
Also have a light weight Tektronics 60MHz scope that the F*K-WADs from FedEx dropped on the front and smashed all the knobs off, broke the front face-plate into 6-8 pieces, and snapped the handle in half. Insurance paid for it 100% but I was wanting a lighter O'scope, not another project...
I actually -just- ordered a Hantek DSO-2150 60MHz USB scope yesterday but it's obviously not here yet so I can't offer a review.
Those usually run $200-$230 or so on eBay.
http://www.hantek.com.cn/english/pro...st.asp?unid=63
There's a long scope discussion here about an Owon Scope and scopes in general:
http://www.badcaps.net/forum/showthread.php?t=6312
Old 05-17-2009, 02:31 AM   #58
MegaOne302
MegaOne302's Avatar
OMG, Bob is here too? That discussion is a must read...
I know what you’re saying, I too am FedUp with FedEx, hope they fold soon.
Thanks for your knowledgeable advice sir.
Keep us informed on the USB scope performance.
Joe
Old 05-31-2009, 12:05 AM   #59
shadow
City & State: Melbourne, Victoria
My Country: Australia
Originally Posted by Toasty
Shadow-
Can you visually check the 3 caps there and report their labeled voltages?
Cheers!
Toast
Bah, finally got around to doing this.
The new CPU cooler that I ordered got lost in the mail!
Australia Post
Eventually I got it and now it is finally fully installed. I checked out the caps while I had the PC case open.
The electrolytic caps are 820uF, 6.3V Nichicon HN(M).
This is the second revision of the motherboard (after the HN(M) capacitor problem plagued this motherboard).
I am surprised that Intel still decided to use these capacitors.
Having said this, the ones that I have are most likely not plagued by the HN(M) capacitor problem. They have been running for years without even a hiccup. Too bad I never bothered to note down the date stamp for the capacitors.
shadow is offline   Reply With Quote
Old 06-12-2009, 01:10 PM   #60
Wizard
You drew a diagram minus a inductor coil! This is vital item. This take pulses from the MOSFETs and inductor coil does a "flywheel" in electrical inertia so ripples and spikes are minimized and futher filtered with v-core capacitors.
Cheers, Wizard
Wizard is offline   Reply With Quote
Badcaps.net Technical Forums © 2003 - 2019
