Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > General Electronics Technical Discussion
Old 10-11-2011, 03:37 PM   #1
Mad_Professor
A Mech Warrior
Mad_Professor's Avatar
City & State: Orlando Fucking Florida
Default Need a new roll of solder what to buy?
Well I never bought solder before, I've had quite alot left over from my grandfather's shop, and now I've used it up.
I've got to order from digikey since I have some caps to order figure that might be a good place to buy from and combine it to my shipping.
Frankly what's good for PSU and MB work?
Mad_Professor is offline   Reply With Quote
Old 10-11-2011, 03:58 PM   #2
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
Default Re: Need a new roll of solder what to buy?
Kester 60/40 "44" rosin core, .025 diameter is what I always use. Always buy leaded, avoid that lead-free rohs shit......you'll thank me later.
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 10-11-2011, 07:29 PM   #3
kaboom
"Oh, Grouchy!"
kaboom's Avatar
City & State: PA
+1000!
That trash is nothing but slag and waste 'marketed and disguised' as solder, as far as I'm concerned! It's "The Enemy" to me, since it was another way to 'enable' or 'lessen the harm' of producing even more cheap junk. How it was sold as 'makes e-waste safer' IS PURE BULL.
Another wonderful EU brainstorm.
"pokemon go... to hell!"
EOL it...
Originally Posted by smashstuff30
guilty,guilty,guilty,guilty!
guilty of being cheap-made!
kaboom is offline   Reply With Quote
Old 10-11-2011, 08:28 PM   #4
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
funny, that is exactly to the point of what I use. it is good stuff.
some lead free works (99/.7), but it isn't as good as leaded. However, on the FIRST robotics team I was on, at competition the only type of solder allowed is for use in the pits is lead free. dumb rule, but the rules are rules.
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 10-11-2011, 08:41 PM   #5
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
I've bought Multicore 63/37 with very small diameter and 2% flux - it works well but I wish I would have chosen one with more flux.
Have to buy one of those flux pens but the only ones that were in stock on digikey were quite expensive ..
mariushm is offline   Reply With Quote
Old 10-11-2011, 09:03 PM   #6
mockingbird
mockingbird's Avatar
Unleaded solder has its uses... If you have a BGA where the leads are very very close, you NEED to use PB free solder because leaded solder flows too freely and the leads will bond to eachother forming one large blob...
Also... unleaded solder is a lot safer now that they've perfected the mixture... The thing is, it's impossible to know which company uses which unleaded solder... Are they using old stock tin/copper only balls, or are they using the new stuff?
But yea, for hand soldering, 60/40 is the way to go. 63/37 is a little more difficult to melt.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 10-11-2011, 09:57 PM   #7
Topcat
The Boss Stooge
Topcat's Avatar
Agreed....but for just about anything that anyone on this forum is going to encounter, my original post is the way to go. If they have to ask, stop reading after my first post. Someone extremely skilled in the art of soldering will know this like they know their own name.
Unless you plan on starting a motherboard manufacturer, reballing chips, or doing massive amounts of SMT reworking of IC's with many dozens of close contact leads on them, 60/40 fine strand rosin core is all you need to know.
Old 10-12-2011, 08:18 AM   #8
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
i grab all the kester "44" i spot at hamfests and flea markets that i can get cheap.like folks that hoard 100w lightbulbs.just a matter of time before its out of production.
kc8adu is offline   Reply With Quote
Old 10-12-2011, 08:25 AM   #9
ratdude747
Black Sheep
ratdude747's Avatar
unless leaded solder is made 100% illegal, I doubt that will happen.
Old 10-12-2011, 01:01 PM   #10
Topcat
The Boss Stooge
Topcat's Avatar
With the tree huggers today, it is very possible. I too grab it when I see it if its cheap. I also have a good hoard of incandescent bulbs...
Old 10-12-2011, 04:31 PM   #11
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
60/40 is a great choice but I prefer 63/37 unless I can't find it.
It's melting point is about 7C lower than 60/40 so it 'gets going' a tad quicker.
The big difference is 63/37 is a eutectic solder vice 60/40 which is non-eutectic.
Non-eutectic solders [like 60/40] have that semi-solid state between solid and liquid so if a joint is moved during that stage it can result in cold solder joints.
Eutectic solders [like 63/37] do not have the semi-solid state and solidify instantly so they are less likely to produce bad joints if you bump the part or work table at just the wrong time.
That said, it's a really minor difference [couple seconds] and more of a style/preference thing than anything else.
In the Navy we always got the 63/37 when we could because soldering in 'a room' that's bouncing and vibrating like a speeding flatbed with out of balance tires adds another element of challenge to getting the job done.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 10-13-2011, 07:27 PM   #12
Mad_Professor
A Mech Warrior
Interesting...
Well I bought the kester 60/40 44 roll for $68 ouch. It better last me forever. LOL
Old 10-13-2011, 07:49 PM   #13
ratdude747
Black Sheep
ratdude747's Avatar
Originally Posted by Mad_Professor View Post
Interesting...
how much?
I usually buy mine in 1lb spools.
Old 10-13-2011, 07:58 PM   #14
Mad_Professor
A Mech Warrior
Originally Posted by ratdude747 View Post
how much?
It was 1lb spool too.
Old 10-13-2011, 08:50 PM   #15
ratdude747
Black Sheep
ratdude747's Avatar
seriously?
I paid less than 1/3 of that for mine... it was $25 at a local EE store iirc.
Old 10-13-2011, 08:59 PM   #16
mariushm
Mine was 42$ : http://search.digikey.com/scripts/Dk...ords=82-129-ND
It's actually 500g, not 1 lbs (1lbs = 454 grams)... or at least that's what it says on the label... maybe the plastic is 50 grams..
Old 10-14-2011, 03:33 AM   #17
Mad_Professor
A Mech Warrior
seriously?
Awwww fuck, I got raped didn't I?
Oh well.
Old 10-14-2011, 12:11 PM   #18
Topcat
The Boss Stooge
Topcat's Avatar
Interesting...
Check fleabay. I score 1lb rolls of it there for 15~20 a roll all the time. Flea markets and things like hamfests, they can be had for about 5 bucks a roll.
Old 10-14-2011, 02:42 PM   #19
yyonline
City & State: Pennsylvania
Kester 44 is good stuff. 0.025" is a good size for motherboard work, and not too annoyingly small for other work on occasion. I also prefer 63/37 over 60/40 for the reasons mentioned above.
I also use Techspray G3 Flux Remover. It's not really required for most rosin core stuff, but it does make the repair look more professional. It works like nothing else I've tried. Spray on and the flux is gone. No rubbing required. Just use it in a well ventilated area or the room will be spinning in no time.
yyonline is offline   Reply With Quote
Old 10-20-2011, 08:46 AM   #20
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Interesting...
Expensive yeah but at least you can be happy to know it won't contain shitty flux.
Agent24 is offline   Reply With Quote
