I aquired a dell dimension 4550 upon inspection inside i came across some leaking caps next to the hsf . My question is, is anyone able to id these.
Dimension 4550
Re: Dimension 4550
Please provide some info on those capacitors such as their brand, series (usually a 2- or 3-letter name), capacitance (in uF), and working voltage (v). This info should be printed on each capacitor. Also note their physical dimensions (in mm), particularly the diameter (most are 8mm, 10mm, or 12.5mm). If possible, also take some pictures.
Re: Dimension 4550
Well if you can get just the info on the caps, that should be enough to help you find proper replacements.
Also, are you trying to upload the pics on badcaps.net? If so, it should be fairly easy: just click on "Manage Attachments" below your post, click "Browse..." for each picture you wish to upload, then click "Upload" once you're done selecting all of the pics. Hope this helps.
