GX270 Substitute cap values?
    This GX270 I have has 9 6.3v 1800uf 8x20mm caps all along the cpu and I have on hand a bunch of 6.3v 1500uf 8x20mm Rubycon MCZ caps. Will these work? or do I HAVE TO use 1800uf?
    I already plan on using them to replace the 1500uf 10x12.5mm ones around the ram slots.
    Let me know please, thanks!
    Re: GX270 Substitute cap values?
    !!!!!!!!!! EDIT !!!!!!!!!
    OK hold up, I'm an idiot. I had my values all messed up.
    Correction:
    The ones along the cpu are 1800uf, I have on hand a bunch of 6.3v 1800uf 8x20mm Rubycon MCZ caps, can I use these to replace the five 6.3v 1500uf 10x12.5mm ones around the ram slots???? I've read I can use 10v 1500uf, but have all these 1800uf and would like to use them if I could.
      Yeah that shouldn't be a problem, as long as the fact that they're physically taller won't cause issues.
