This one came into my shop yesterday.
E-machine T2040
Re: E-machine T2040
Agree. If it has a bestec (worstec) PSU, replace it or re-cap it as it will take the board out if it hasn't done so already.I love putting bad caps and flat batteries in fire and watching them explode!!
Re: E-machine T2040
Welcome to the forum.
Is that reddish color from your camera lighting/flash or is that something else?
Looks like you have lots of bulging capacitors there. What kind of power supply does it have (brand and model number)? The power supply might be the deciding factor in whether or not you want to recap the mother board.Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
Re: E-machine T2040
Originally posted by c_heggeAgree. If it has a bestec (worstec) PSU, replace it or re-cap it as it will take the board out if it hasn't done so already.
By the way, what is the brand of the failed caps? Seems like TMS (a.k.a. Total Monkey Shit) but I can't tell from the photos.
Re: E-machine T2040
PSU is Bestec ATX-250-12E. Tried recapping mobo, but the new solder would not take to the mobo. The computer was left out in the "barn" for a while.
I trash the mobo. The CPU and ram seem to have survived the abuse. I will be checking the PSU today.
The red is on the caps. Some type of corrosion, I believe.
Jon Nailor
Re: E-machine T2040
Originally posted by momakaThat would be the Bestec ATX-250 rev 12E only. Other Bestecs don't usually have this problem.
You guessed right. TMS 105C 6.3v 1500uf
Re: E-machine T2040
Originally posted by ArcticwolfNew update. PSU checks out. No bad caps there.
With that said, don't use this power supply on any motherboard, ever. Use it for parts only (fan, wires, coils, and the 200v primary capacitors).
Originally posted by ArcticwolfTried recapping mobo, but the new solder would not take to the mobo.
Also try putting a little bit of solder on the tip before soldering. This should improve heat transfer.
When you recap the motherboard, try it with a different power supply. There is still a chance that it will work.
By the way, what brand and series of capacitors are you using as the replacements?Last edited by momaka; 11-30-2009, 12:44 PM.
Re: E-machine T2040
I use 2 irons, one 30w and one switchable 35, 50. Niether would work. Solder other boards with no problem. It is just this board.
I replace with Rubycon, when I can.
Jon NailorLast edited by Arcticwolf; 11-30-2009, 01:29 PM.
Re: E-machine T2040
You could send it to Topcat and he could re-cap it for you. I agree with momaka about the PSU. There are more problems with the Worstec ATX-250 rev. 12E than the caps, so either toss it out or use it for parts.I love putting bad caps and flat batteries in fire and watching them explode!!
