Dell XPS AC Adapter Unknown
    Dell XPS 15 9560
    Power Adapter and Power Jack are ok
    Laptop = 19.5v --- 6.67A --- 130w
    Power Adapter = 19.5v --- 6.67A --- 130w
    error :
    Alert! The AC power adapter wattage and type cannot be determined. the battery may not charge. the system wil adjust the performance to match the power available
    Re: Dell XPS AC Adapter Unknown
    sounds like the old 1wire problem.
    a memory device in the charger that the laptop reads data from.
    NOT faulty usually, but caused by a bad connection in the cable.
      Power adapter is ok
      power jack is ok
        I found this, give it a try, it turns off the warning in the bios https://www.dell.com/community/XPS/W...d/td-p/6045885
          Originally posted by medinfo View Post
          Power adapter is ok
          power jack is ok
          the white wire is a data wire to a memory chip in the charger.
            it only disables the error message, does not fix the problem (R_J)
              Are you using original Dell adapter or third party adapter?
                Original Dell Adapter 19.5v --- 6.67A --- 130w
                  I've seen this A LOT on returned laptops. I think what happens is those newer adapters simply have a very crappy cable that looses/breaks the middle (ID/identification) pin. So despite the power adapter outputting the proper voltage, the laptop cannot properly ID the adapter and thinks it's a generic/no name and/or low-power adapter.
                    sometimes cables break, sometimes static kills the chip - it has no zener diode or similar to protect it.
                    there is pic chip code floating around to simulate them.
                      Problem fixed
                        and the problem / fix was??
                          LOL.
                          Don't you just love it when they say that!
                            i see it too often!
                              LOL
                              Or it could be —> do not want to deal with anymore
                              9 PC LCD Monitor
                              6 LCD Flat Screen TV
                              1 Dell Mother Board
                              15 Computer Power Supply
                              All of these had CAPs POOF
                                i see it too often!
                                When I do, I no longer read that person's threads - particularly help requests.
                                  Dell 5470 unknown ac adapter I replace charger an motherboard caple and I face the same proplem what can I do ??
                                    get a schematic and check the 1wire bus circuit.
