Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Old 03-25-2019, 06:21 PM   #21
R_J
City & State: ☻
My Country: Canada
Default Re: Help identity blown part in Alesis Mixer PS
I suspect the MK-328 can't measure it properly. I will ask again, Is the power supply working or not?
R_J is offline   Reply With Quote
Old 03-25-2019, 06:22 PM   #22
Carm99
City & State: London
My Country: England
Ill have to replace the 2200 cap and the small ceramic one then see if it works.
Ill let you know after that, what happened hopefully it wont blow the small cap again. again.
Thanks so far anyway.
Carm99 is offline   Reply With Quote
Old 03-25-2019, 06:29 PM   #23
R_J
City & State: ☻
My Country: Canada
That small cap likely went on its own. and if you want to try the supply you can try it without that cap. installed for now. Like I said I doubt that 2200f cap is bad, if it was it would have either leaked or bulged.
The most voltage across the small .1f is 25 volts, It is not uncommon for them to fail shorted
Old 03-26-2019, 07:50 AM   #24
R_J
City & State: ☻
My Country: Canada
Originally Posted by Carm99 View Post
The 2200 big cap on the board is testing 0.00Ω esr.
Did you happpen to check the capacity of the cap also? or just the esr? That 0.00Ω esr seemed a bit odd to me. I guess the cap could be completely open and not measuring anything
Old 03-26-2019, 09:09 AM   #25
Carm99
My Country: England
Its not measuring any resistance on a multimeter either so I swapped it for a new one.
Power supply works now.I didnt leave it on for long though.
Im gonna check it again later.
Old 03-26-2019, 09:37 AM   #26
R_J
City & State: ☻
My Country: Canada
It could be that the 2200 went open and the poor little .1uf tried to do the filtering and failed.
Try using diode test with your meter, that should show something, then reverse the leads and check again
Old 03-26-2019, 10:26 AM   #27
Carm99
My Country: England
I tried that. It was the same.
Im gonna replace the rest of the caps anyway. Also those two 0.1uf ones.
Old 03-26-2019, 03:40 PM   #28
sam_sam_sam
City & State: Sunny Jacksonville FL
Line Voltage: 120 Volts 60 HZ
Not necessarily meaning I had a capacitor ESR reading like that and when I check the new one I got the same exact results
I was also confused as well with the results
In fact I check this capacitor with a capacitor tester that checks UF readings and it readings were what should have been but I did replace it anyway
I would check a new capacitor with same exact UF value and the same exact voltage see if you get the same exact results
9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these had CAPs POOF
sam_sam_sam is offline   Reply With Quote
