216-0833002 compatibility?
    Hello everybody & happy new year.
    Been trying to find a solution about this chipset. I have received several VAIO laptops with this chipset that had problem on the picture, no picture or scrambled picture with artifacts (gpu chipset problem). Now my trusted dealer can't find a new one for months and I have already tried 216-0833000 but with no result.
    Has anyone find a compatible one or can suggest a trustworthy dealer? I have purchased from ebay those saying 100% brand new but unfortunately after 15-20 days the laptops come back so it is not good stuff.
    If I can remember correct Toshiba laptops have the same chipset too. I can tell for sure that on laptops with 216-0833000,216-0833002 works perfectly but not the opposite.
    Thanks in advance!
    Re: 216-0833002 compatibility?
    Changing that chip requires modified bios that can work with another. There are moded bios somewhere on forum for toshiba with same chip substitute
    Im Back... sort of...
      Thanks for your kind reply but the laptops that I need a substitute chipset are mostly VAIO series SVE17 and SVE15 that have 216-0833002. I don't think that there are modded bios files for these machines. Can anybody suggest a trustworthy dealer with new chips of this type or if someone had success using a substitute for this one would be very helpful for me.
        Originally posted by lefos View Post
        hello,
        thanks for your kind reply but the laptops that i need a substitute chipset are mostly vaio series sve17 and sve15 that have 216-0833002. I don't think that there are modded bios files for these machines. Can anybody suggest a trustworthy dealer with new chips of this type or if someone had success using a substitute for this one would be very helpful for me.
        did you fix this problem
          @crowntoy99 I had success on sve15 & sve17 laptops swapping 216-0833002 with 216-083300.
            @crowntoy99 i had success on sve15 & sve17 laptops swapping 216-0833002 with 216-083300.
            thank you for replay
            what about bios did you have bios ?
              THANKS for info solved replace 216 083002 to 216-083000
                what laptop model bro? did modify the bios firmware or not.
