Hi there,
i am currently fiddling with a samsung monitor/tv combo.
Backlight cuts out after about a second, picture seems fine otherwise.
1. I touched up some suspect solder joints especially at D109 wich seemed to be quite toasty give the color of the PCB
2.Tested some caps in circuit and desoldered some but ballpark numbers seemed okay(device used was the M-Tester)
3.Measured resistance on the inverter transformer, very low ohm on the primary and about 1.3k ohm on the secondaries.
4. No idea what to do know, probably measure voltages on the live board, wich i kinda wanted to avoid...also i got no spare CCFL..
