weird help needed
    weird help needed
    I need help finding a part number for this tiny break-beam sensor.
    I joined pictures with dimensions. sorry for the bad quality but what im trying to fix is my actual camera hehe. you can see one side is broken off and gone.
    basically, they are roughly 100mil by 65mil. Post your suggestion on what they could also be called.
    Re: weird help needed
    cant see any pictures - did you forget to attach them?
      they are attached and showing on my end.
      Heres the straight links :
      http://i213.photobucket.com/albums/c...s/IMG_1709.jpg
      http://i213.photobucket.com/albums/c...s/IMG_1710.jpg
      http://i213.photobucket.com/albums/c...s/IMG_1712.jpg
      http://i213.photobucket.com/albums/c...s/IMG_1711.jpg
        What make/model are you repairing?
        I can't make out much from those pics. Trying to imagine it not busted into two pieces. Did find things like this pic
        PS Quebec is on the Metric system, all dimensions I found are Metric
          [QUOTE=redwire;744079]What make/model are you repairing?
          PS Quebec is on the Metric system, all dimensions I found are Metric[/QUOTE.
          yeah, thats what it is on your picture. thats how it should look
          It's usually used in conjunction with an encoder wheel .
          I posted in imperial because thought people were more used to it on here..
          The dimensions are 2.5mm by 1.5 mm
            ah ! they are not in optoelectronic but in sensors on digikey. I digging in there, I may find the right one
              Redwire, you win the internets. they are indeed sharp GP1S396HCPSF Just like you posted.
              1.2mm slot, even look exactly the same. THANKS
                They are not advailable under 12 000 quantity on digikey and mouser has them in backorder.
                Nothing on ebay .
                Do you guys have other such places to order from ?
                  email sharp .. if they are as nice as other companies they will send some out to you free of charge .. i like to ring them on the phone rather than email .. worth a shot either way ..
                  https://www.sharpsde.com/products/op.../GP1S396HCPSF/
                    You can find it here
                    http://alibaba.com/ In the search bar put your part number there a couple of vender that sell one or more
                    9 PC LCD Monitor
                    6 LCD Flat Screen TV
                    1 Dell Mother Board
                    15 Computer Power Supply
                    All of these had CAPs POOF
