Issue with Westinghouse 19" LCD Monitor (large pics)
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Crabs?
    Anyway, I didn't know if the Taicon caps were better Quality or not since none of them are bulged. I took some more pics of the back of the board. let me know what part of the board and I can take very close shots if I can't find it myself.
    Thanks,
    Bob
      I can see 2 fuses
      F200 on first pic, at bottom in middle
      F102 on fourth pic, top left with a M or W on it
      suspect there may be a third possibly F101 (not sure about that)
        Originally posted by bcuda
        Crabs?
        Thanks,
        Bob
        He refers to the 8 legged ICs near the transformer.
        If you can, replace those Taicon for Panasonics as a preventive measure.
        And check the fuses Bob describe. On the model discussed here before, with the different PSU from yours, F200 was the culprit. Check them both, F200 and the "W"/"M" one ...
        • ASUS ROG Maximus IX Code
        • Intel Core i5-7600K 3.8GHz
        • Windows 10 Pro x64
        • GeForce GT1050
          Nama could have at least drawn a couple of eyeballs on stalks on the end of them, and made it easier to understand
            They are undercover .....
            • GeForce GT1050
              look at the chips they have crabs on them. Or am I mistaken>>>???
              I have a untested board for your monitor. Maybe you want it or parts off of it?.
              ^Learning to walk on rice paper without leaving a trace,
                That's Realtek logo. Not that one. This is microcontroller (aka minimalist cpu with few control outputs and few inputs).
                The IC they were referring is FET drivers in 8 pin DIP package (on the inverter/power supply board). Black square, dot or notch for pin 1, with 4 legs on each side in parallel.
                Cheers, Wizard
                  hello I need help, where can I found the service manual for this LCD monitor
                    Diffucult task. What problem do you have?
                    • GeForce GT1050
                      I have an acer AL1916Wa LCD monitor, and it does not turned on. The power sorce and the controller card are the same
                      I have a monitor that has exactly the same source and the same control card, as yours, but mine does not turned on, I check the voltage of the source 13.8v and 5v are ok. what can I do.
                        I tested the two fuses. F102 is good. F200 is bad. It has a #3 on it as best I can tell. Where do I get one of those and how do I know the value of it?
                        A parts board would be great but I hope all I need are the caps, chips, and the fuse. I already ordered the mosfets off of Ebay.
                        Thanks,
                        Bob
                            I would suggest starting a new thread. even if you barrow bcuda's pictures. It gets very confusing for people to reply to multiple questions from multiple people in the same thread.
                              Open a new thread with the Acer model ....
                              • GeForce GT1050
                                Thanks,
                                Bob
                                F200 as in our models ....
                                Get new caps, MOSFETS and I think the fuse is either 3 or 4 amps (that info is around this or the L20146NV thread that I started). Mine is bridged with solder.
                                • GeForce GT1050
                                  Just an update, The caps and fuse are in. Waiting on the chips to come USPS. I thought they would be here today but not luck. Maybe Monday.
                                  Bob
                                    Got the mosfet's in today. The monitor works great!
                                    Thanks for all of your help guys!!
                                    I will be checking back here frequently.
                                    Thanks again,
                                    Bob
                                      Congrats !
                                      • GeForce GT1050
                                        The fuse on the bottom of the power supply board is a 4amp surface mount fuse. Mouser.com carries them, they are part number
                                        652-SF-1206F400-2
                                        We have repair many of these units and every time its the caps, mosfets and the fuse.
                                        Buddy
                                          652-SF-1206F400-2
                                          Buddy
                                          Agree : caps going south kill the mosfets, that in turn blow the fuse.
                                          And I recall seeing the part # and amp rating somewhere around here, just can't remember where. Thanks for the info, man!
                                          • GeForce GT1050
