Sony SMD-HS73
    Re: Sony SMD-HS73
    Originally posted by retiredcaps View Post
    Just out of curiousity, what is the part number for IC2 on the backside of the power board?
    200D6 PZDC
    This looks like it should be right.
    http://www.alldatasheet.com/datashee...1200D60R2.html
      Re: Sony SMD-HS73
      What is the model number for Q3?
      --- begin sig file ---
      --- end sig file ---
        Re: Sony SMD-HS73
        Sorry, one more. What is the part number for the diode that is providing the 12V rail? It will be one of the two that is mounted on the heatsink.
          Re: Sony SMD-HS73
          SSS6N70A 341
          http://www.alldatasheet.com/datashee.../SSS6N70A.html
          I had to remove the cap from in front of it to get the number...
          UD6340 STPS10 150 CT
          http://www.alldatasheet.com/datashee...STPS10150.html
            Re: Sony SMD-HS73
            Sorry I haven't been working on this one while I was waiting for my Blue ESR meter kit to arrive. I came in Monday and I put it together last night. I seem to have gotten it right the first time.
            Anyway, I've been testing some of the caps I pulled off this board. It has been long enough that I'm not 100% sure of which through-hole caps were from this board, but for the logic board, it was the only one I removed SMD caps from. 3 of them seemed to be likely bad based off of the FC series data sheets. (I can't tell what brand, the only markings other than voltage and capacitance is what looks like 30I1 on the 47uF, and 3a on the 10uf cap, all 16v.)
            The 10uf cap was at 15Ω, as opposed to the FC spec at 3Ω. The 47uf caps were at 6.2Ω & 7.3Ω compared to the FC spec at 1Ω.
            I should be working more on this board over the weekend. I'll be trying to trace down possibly bad components on the board.
              Re: Sony SMD-HS73
              Just remember that if the equivalent FM caps are available, they have even lower ESR.
                Re: Sony SMD-HS73
                Ok, I'm apparently completely missing the point you are making.
                Since I've already replaced the caps with FC series caps I'm not planning on replacing them again unless they go bad. I don't know what brand/series were on there originally, so I can't say for certain that they are out of spec, but again, going by FC specs, they certainly seem to be going bad. Especially since 3 other caps, including at least 1 more 47uF cap all tested much lower.
                But I'm not sure why you are telling me that FM would have lower ESR. I'm aware that relative to FC there are caps that would have lower or higher ESR specs in those can sizes.
                  Re: Sony SMD-HS73
                  No real point. Just trying to say that FM has lower ESR than FC.
                    Re: Sony SMD-HS73
                    Ok. No problem. Just wanted to make sure I wasn't missing your point.
