I'm an IT guy who works w/ computers every day. I don't normally deal w/ component level problems. I've been dealing w/ a lot of these shuttle size systems w/ small cases and blown caps. Generally they either won't POST which is what this one does, or they POST and immediately lock up.
I've been having a discussion w/ some of my coworkers. I've always worked on the theory w/ caps that if they're bulged or leaking they're bad. Even if they aren't bulged or leaking they may still be bad. Others who know far more about board level electronics insist the caps are just a filter and the system should run fine w/ them bulged/leaking. From what I understand, the caps where these are located help control the voltage to the processor. Is this correct, and what would be the consequences of having these caps in this condition?
This board won't POST so left to my own devices I'd say this board is bad and needs to be either recapped or replaced. I'm looking for the technical reason to tell a boss as to *WHY* the system won't work in this condition.
Thanks in advance to anyone who takes the time to look at this and reply.
