Acer AL2423W: Recapped, Still Dead!
Re: Acer AL2423W: Recapped, Still Dead!
Originally posted by Kridian View PostHere's my inverter:
You might as well replace them too.Last edited by retiredcaps; 12-24-2010, 07:55 PM.--- begin sig file ---
--- end sig file ---
Originally posted by Kridian View PostPico fuses voltage left to right: 1.2, 0.6, 0.4
Is that good?
Put your multimeter on 200 ohms (if manual). A good fuse should measure less than 1.0 ohms.--- begin sig file ---
Originally posted by Kridian View PostI have this digital pocket multimeter so I can't set it to 200v. I checked them again (no power) and they're all around 1.2--- begin sig file ---
Other than that does the monitor come on?
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...7&d=1280167246
https://www.badcaps.net/forum/attach...6&d=1280167246
https://www.badcaps.net/forum/attach...4&d=1280167246Please upload pictures using attachment function when ask for help on the repair
Originally posted by wifi View PostHi, I have a problem. Power board has new capacitors. C1 also new. Monitor is switched on, 5V, 12V, 19V works, but oddly whistles and D14 power board with very warm and falls out of position. IC6 is also new. Does anyone have an idea? Thank you
Originally posted by wifi View PostD14 diode PG5408 is defective= 215 ohm, but why?
Pictures?Please upload pictures using attachment function when ask for help on the repair
Originally posted by wifi View PostD14 diode PG5408 is defective= 215 ohm, but why?--- begin sig file ---
Thanks some odd joints on the back but if you were getting 5v 12v and 19v
the diode should be ok.
Did you test the diode like this:
a) put your multimeter in diode test mode
b) put your black lead on one side and the red lead on the other - record reading
c) reverse the leads - recording reading
A good diode should read 0.4 to 0.7 in one direction and 0L in the other. If you get a reading in both directions, you will have to desolder one leg and retest as an "in circuit" test may not be conclusive."Please upload pictures using attachment function when ask for help on the repair
Great!! well done - thanks for reporting backPlease upload pictures using attachment function when ask for help on the repair
