Graphics card Schematics and Boardviews
This is a sticky topic.
    Re: Graphics card Schematics and Boardviews
    Originally posted by poprom1965 View Post
    schematics GigabyteN760 OC-4GD please
    https://smd.db-x7.ru/search/?q=GV-N760OC
      Originally posted by coco666 View Post
      Hello
      Could some one help me???, i'm looking for the shematics and Boardview for the Radeon RX 5700XT
      https://smd.db-x7.ru/search/?q=GV-R57XTGAMING
        I´ve got a gigybyte GTX780Ti OC and need the Boardview please.
          Does anyone have a boardview for a Zotac GTX 1070 Amp Edition? Thanks!
            https://smd.db-x7.ru/search/?q=GV-N780OC
              Please I need a board view for Radeon RX 460.
                https://smd.db-x7.ru/load/boardview_...-11200?aAnmfcw
                  I Need Board view for MSI RX460.
                    Originally posted by Rezistor View Post
                    Thx but thats a non Ti. I need the Ti in cause of the 2 8Pin Pex Connectors.
                      Originally posted by Chickenhawk View Post
                      Hi, I'm looking for Boardview for ASUS GTX 1070 Dual (not the Strix) # CG411A. Thanks!
                      https://drive.google.com/file/d/10C5...ew?usp=sharing
                        its similar
                          hi this is boardview ASUS DUAL GeForce GTX 1060 OC 6GB DUAL-GTX1060-O6G CG410PLM 1.01
                          https://drive.google.com/file/d/10C5...CMItPss3v/view
                            hi does anyone have a board view or pdf for gigabyte gv-n1080wf3oc-8gd or know if the 1070 wf2 is the exact same trying to figure out 2 componuts on the board located at R990 and R991 if theyre resistors or not and values any help would be apperciated thank you
                              I've found out that they're all pretty much the same. You just have to find the same sections on each variation of 10-series.
                              So the 1.8v, 5v, etc tend to use the same parts and components but may have them in different spots on each make of card. So, your parts will likely be on any other 1070 boardview you can find but you just have to find them (by pattern or location).
                              I just wouldn't use a 1070ti or the like. If you have a normal 1070, use another normal 1070 boardview.
                              Also, there are outright schematics for a 1070 on here and that may also help you if you can identify what rail those components you need are on. Good luck!
                                Hello everyone.
                                I'm looking for Gigabyte GTX 980Ti (GV-N98TG1 GAMING-6GD) Schematics, as I'm trying to fix a blown Mosfet & Capacitors at the bottom right side of the card.
                                Thank you all very much in advance.
                                  Originally posted by DetectiveStrawberry View Post
                                  Hello everyone.
                                  Hello! IIRC, most 980ti cards are similar across manufacturers. Similar parts and designs with some slight variations in placement. There is one on page 13 for another manufacturer so check that out.
                                  Also, if you find one for a TitanX card they're identical.
                                  PS: I recently fixed an EVGA 980ti SC 6GB. In may be able to help you if you DM me a photo of the cap and mosfets issue in question. I even have a few of the mosfets left over to possibly test on if it's an issue with that.
                                    Hello everyone, I am looking for the schematic of an Asus gtx 1650, I have to find a replacement for an Ic, which only says "53C3" is of the SOT-23-5 type, but I don't know what it is, if someone can help me . Greetings
                                        MSI MS-V3xx ??? Rev xx ???
                                          Thank you, ive got a few differnt board views and schematics here my problem is board view is showing something that looks like maybe a ferite bead then on the pdf ones i have its showing resistors a 10k and a 0ohm this is a little confusing here is a picture of what they actually look like on the gigabye 1080 board i have one is located at r990 and the other is r991
