Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 09-14-2020, 08:09 PM   #1
tonebells
City & State: Port St. Lucie
My Country: United States
I'm a: Knowledge Seeker
Default UN65HU9000 T-con
I have a UN65HU900 that CD3011 on the T-con shorted. It has no markings. Dose anyone know what it may be? I can not find service info anywhere.
T
tonebells is offline   Reply With Quote
Old 09-15-2020, 03:50 PM   #2
budm
budm's Avatar
City & State: S.F. Bay area
My Country: USA
Line Voltage: 120V 60Hz
Default Re: UN65HU9000 T-con
Please attach good clear pictures of the board so we can see what we are dealing with.
__________________
budm is offline   Reply With Quote
Old 09-16-2020, 04:47 AM   #3
tonebells
Here are some pictures. Let me know if you want to see anything else.
T
Old 09-16-2020, 06:38 AM   #4
Kilroy2k1
City & State: Ontario Canada
At the risk of sounding like a half a$$ed fix.. When i cant ID a part like that I usually look for an exact size match off a donor board, 9 times out of 10 the value is close enough that the circuit just dosent care.
Kilroy2k1 is offline   Reply With Quote
Old 09-16-2020, 02:06 PM   #5
budm
budm's Avatar
My Country: USA
What is the P/N of that ICD3?
i should be the same capacitance of the cap used on the left side of the board where it is connected to the same type of 6-pin IC on the left side..
Old 09-16-2020, 06:49 PM   #6
tonebells
Quote:
I almost did that.
T
Old 09-16-2020, 06:50 PM   #7
tonebells
Great thinking. I will look.
T
Old 09-16-2020, 06:56 PM   #8
tonebells
The part numbers on the left are all the same less the 30. so CD3011 should be the same as CD11. I will see if I can get it off without killing it.
T
Old 09-16-2020, 08:20 PM   #9
mmartell
City & State: Windsor ON
My Country: Canada
Does the tcon work without the cap ? You may have other problems beside it.
mmartell is offline   Reply With Quote
Old 09-17-2020, 04:26 AM   #10
tonebells
Quote:
I have not tried it yet. I was going to hook it up to my bench supply and see if it has any other shorts. I have a replacement on the way. I like to try and fix things like this to learn.
T
Old 09-17-2020, 05:07 PM   #11
tonebells
I was able to hookup 12 volts to the board and nothing over heated. I have a new hot air station coming. I will see if I can find out what value CD3011 is.
T
Old 09-18-2020, 02:49 PM   #12
tonebells
It is a 10uƒ. With 12 volts applied the current is even lower then before I replaced it.
T
Old 09-20-2020, 11:58 AM   #13
tonebells
That has done the trick. It is working. I will let it run for eight hours tomorrow with the cove on to see how it goes.
T
Old 09-20-2020, 03:37 PM   #14
budm
budm's Avatar
My Country: USA
Thanks for the follow-up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2020
Powered by vBulletin ®
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
