Dim Mitsubishi WD-73738 DLP Telivision
    Re: Dim Mitsubishi WD-73738 DLP Telivision
    Originally posted by budwich View Post
    As indicated above... if the color wheel causes an issue (ie. such as the system is unable to detect proper spin speed), then in most cases, this type of error "usually" occurs at startup, and the lamp would normally not be "striken" (started). However, if the error occurs during "normal run" then its possible that the unit would then shut down the lamp to prevent damage to a slow wheel or otherwise. You can check this with a "viewing" test" such that when the image disappears, look "carefully" at the light engine to see if the lamp is still lit. Of course, if you can eventually get a display again, you could also check the "counters / errors" to see if there was a "0061" happening again.
    Further, in DLP land, brightness of an image is usually achieved in two ways: one from the actual bulb rating and two from the color wheel itself. On some designs, a "blank" / white segment is used for both sync AND improved brightness levels. I am not sure about the Mits design but other projector manufacturers (eg. optoma) use this mode. On your wheel, what is the colors segments specifically going around the wheel?
    Further: Looking at a bit of stuff around this, it would appear that perhaps, then sensor is able to determine intensity of light in terms of range such that the main control can decide on how long to "turn on" the dlp chip segments to brighten or reduce intensity. It maybe possible that the sensor is coated with gunk such that this "work" is wrong... or there is a wiring issue. There might be some checks for this or perhaps some cleaning (carefully) of the sensor. What maybe happening is that the sensor is not detecting sufficient brightness as "requested" by the controller, so the controller is upping the "dlp activity" level to get more brightness. However, the system feedback via the sensor still does not show the expected "improvement" (or runs out of "on off" cycles for the dlp) and thus eventually the system "errors" and shuts down.
    I think the Red and Yellow wires being shorted out is what's throwing the 0061. It might be hard to tell from the pics, but the yellow, red, and black are all twisted together, and the yellow and red have the insulation melted off about equal distances, both shorting out. The way it was wrapped, it wasn't like a full short, it was like eh, they could be touching, they might not be touching. I think this made it intermittent.
    The colours on this wheel are (in this order):
    Blue
    Red
    Green
    Blue
    Red
    Green
    So there's two of each colours, and they're 180 degrees apart from each other. So you have the Blue, and directly on the other side of the wheel is another blue.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      it is likely the. wiring. provides a "pulse stream" back to the controller.... hence if they are missing or otherwise then the system may error. the twist may be important in terms of. signal interference... maybe. you might try some liquid insulation on the bare parts first along. with checking for shorts between wires with a meter to verify a problem.
        There was definitely a short between the wires, the way they were twisted. Man, that was a hard fix. I mean, the fix itself was easy. Unsoldered the three wires, cleaned the board, chopped off the bad parts, soldered new black, yellow, and red wires on, used heat shrink tubing to insulate them, twisted them the best I could, then soldered the new wires back to the board.
        Worked like a charm and the TV appears to be working properly now.
        The lamp energy level is set to Bright. Contrast is all the way up to 63 (the way it was when I received it). It doesn't appear as bright as I would have thought it'd be, but it's brighter, not dim like it was. I think it might be just different than what I'm used to. The picture quality is nice, but richer, maybe more than my plasma. So I think perhaps it's just something I'm not used to.
        Lamp itself is burning nice and bright. Putting off a good amount of heat as well. I think this TV is officially done now. No more burning smell of plastic either. Originally, I thought that was just from the dust, but it didn't smell right, smelt like burning plastic. I bet that's exactly what it was. Smelt it the first time I turned it on, before I opened it up and saw all the dirt, but didn't see anything burnt back then.
        Thanks for all the help guys!!!!!!!!!
          good deal. Personally I like the dlp picture (mine is a samsung led based optical engine). The picture is good, glare from the room is reduced (screen finish is not gloss) and there is no worries about burn in.
          happy viewing.
            happy viewing.
            So that uses LED for a light source? Is it possible to somehow modify another make / model, such as this Mitsubishi, to use the LED optical engine? If so, I'd like to do that very much so. This mercury lamp is putting out soooo much heat, it worries me.
              :-) you got the wrong model mits.... you need a laservue one.
              Anyway, it is not a "simple" light source swap... the light engine does not have a color wheel because the "bulb" was replaced by three color leds that flash like a "fake" light wheel. Its disappointing that both mits and samsung abandon the design. People wanted "flat thin" that could be hung on a wall for "sexy". Ultra short throw projectors (front) are still alive and DLP continue to be one of the main stays even with 4k. They are just starting to roll out "affordable" laser / led based units (low powered / light output leds have been out for a bit).
                I did not know laser / LED based units where available. That is amazing, they can do 4k with DLP technology. Even the 1080 impressed me. That's one little tiny mirror per pixel, correct? So over 2 million mirrors in a little tiny chip for this TV. Insane!
                And yeah, it seems people want thin right now. I've seen on Samsung's site some of their new Always-On TVs, where when you're not watching TV, the TV looks like a painting or something just hanging on the wall. Kinda nice I guess, but more money than what I got for a TV!!!!!
                Friend of mine had a real nice DLP projector, 1080 hi-def (I'm guessing progressive) and he was gonna give it to me after he finished using it! But he was dating a girl, she let a friend of theirs borrow it, and then the two of them split up and he never seen her or the projector again. I guess it was around 1,000$, if not more. Real nice one.
                  The laser rear projection tv's don't use a dmd chip, consider it to be similar to a crt but instead of 3 (rgb) electron guns scaning the phospher screen you have 2 or more laser's of different color scaning a screen.
                  Hisence has a 100" laser http://hisense-canada.com/laserTV $9,999.99
                    my oops... my description was more for the samsung dlp design.
                    Spark_shivago, the dlp chips used in most of the affordable 4k projectors are not 4k "mirrors on a chip". the system use a "wobble" system to move a given mirror in 4 directions such that there are only "1K" mirrors. In the samsung RPTV dlp, it is only "512" mirrors which are "wobbled" in 2 directions. The "wobble" can be done fast enough during the picture "build cycle" such that the viewer basically sees 1k or 4k depending on design. Lots of discussion on the pros and cons of the display system in various forums on the networks. Basically, the "wobble" allows for small chips and those a cheaper production design along with other things.
                    Anyway, enjoy your RPTV since it is unlikely that they will ever produce a "new version" again.
                      Added note, the mits laservue sets use a dlp chip in the design.
                        Thanks guys! It's not my TV, just one a guy brought me to fix. Pretty good gig right now. He brings them, I fix him (he pays for the parts), he sells them, we split the profits (minus price for parts). Working pretty good right now. Lot of work, usually easy fixes, but now we get some Samsungs that are not so easy to fix. Beautifully built, but hard to diagnose.
