I was gifted one of these today:
It is a 1966 Heathkit 10-12 AC 1 channel scope.
It used to belong to one of the EET professors at my college... he built it from a kit when he was my age and no longer had a use for it. He thought I might have a use for it and offered it
He even had the original manual in a large 3 ring binder of manuals... he built a lot of heathkit kits...
It works:
(a 12V wall wart without load, synced to line AC frequency)
Since you can use bannana plugs with it, my PSU tester from another thread pairs well with it:
I have one question:
It uses a 2 prong non polarized plug, being from 1966. it also has a metal case. the cord is still good (no cracks, frays, etc). Should I:
1. keep the power cord that is in it... it is vintage and it isn't worth it to mess that up
2. swap it for a modern 3 prong grounded cord, with the hot going to the fuse, neutral to the other line connector, and ground being connected tot he case with a ring terminal and rivet
Otherwise, I am happy with it...
Any other comments/suggestions?
It works:
