I have a 12v car air pump that you plug into the “cigarette lighter” socket (12v socket)
It works fine for pressures up to 50 psi but anything over it starts pulling a lot of current and blows the fuse.
First thing I tried was powering it off an old pc power supply at the 12v supply. This works well for pressures up to 80-90psi then it trips the power supply and turns it off.
The pump says 250psi on it but clearly it's not able to output that much.
My question is, could I add a capacitor across the motor leads to give it a boost that will let it pump out more air under pressure?
I'm trying to use it to fill bicycle tires that require 115psi and was hoping to modify the pump to do that
