Re: Harman Kardon AVR130 - Issues
The memory backup I believe is that 3.6 volt battery. Thats the POWER_H line, it has no voltage because the amp is off. that does NOT mean the micro is bad. at least yet. Near the battery is IC85, 3 pin reset chip, what are the voltages on it? one pin is ground (3) pin 2 is input (should be around 3 volts) output is pin 1
It could be the micro is being held in reset and not allowed to run
Reset pin(77) connects to J706, what is the voltage on that line
