Go Back   Badcaps Forums > Motherboards with Bad Capacitors > All Others Motherboards
Old 01-05-2019, 05:07 AM   #1
caspian
City & State: Mainboard
My Country: Laptop
I'm a: Hobbyist Tech
Question Low Voltages on Desktop/Laptop Mainboards
Dear forum members,
When I measure voltages on desktop/laptop mainboards, sometimes I measure something a bit lower than expected. For example, instead of 1.05v on PCH, I measure 1.047v. Or instead of 1.5v, I measure 1.48v.
my multimeter is OK. and the voltage values are stable at 1.047v and 1.48v.
other voltages such as 3.3v and 5v are normal as expected.
resistance on the 1.047v line is 6.5 ohms.
Do you think these values are normal?
Or should I replace the buck converter circuit or its capacitors or anything else?
Do you think the PCH is getting faulty such that its resistance dropped a bit and this drop has led to a drop in voltage?
thanks
caspian is offline   Reply With Quote
Old 01-05-2019, 01:18 PM   #2
on/off
on/off's Avatar
City & State: Forbidden
My Country: Indonesia
Line Voltage: 220VAC 50Hz
Default Re: Low Voltages on Desktop/Laptop Mainboards
For me...Look like still in tolerance value, all you've measure are parts that feeding the load for low volt and high ampere.
on/off is offline   Reply With Quote
Old 01-06-2019, 12:14 AM   #3
caspian
My Country: Laptop
any experience on such low voltages, please?
how does you mainboard behave with such low voltages?
Old 01-09-2019, 01:55 AM   #4
caspian
My Country: Laptop
what is the reason behind such low voltages such as 1.047v instead of 1.05v on a working mainboard?
Old 01-10-2019, 11:17 PM   #5
brethin
City & State: Owensboro, KY.
Line Voltage: 120VAC 60Hz
That's not considered low, it's within tolerance.
brethin is offline   Reply With Quote
Old 01-10-2019, 11:38 PM   #6
Sparkey55
City & State: OK
Volt meters come in many types depending upon the useage. High impedance input meters like VTVM, DMM and some FETVM are more accurate at reading voltages than say a cheap meter like a battery tester as an example. Low impedance input meters will read lower on the scale because they load down the source voltage. Your readings are within the tolerance of the given said voltages so dont be concerned about the differances.
Sparkey55 is offline   Reply With Quote
Old 02-25-2019, 09:57 PM   #7
desert-rat
City & State: Avondale AZ
Even good meters will vary a bit . To me if it works , I dont worry about it . You might see what other volt meters you can buy/barrow .
desert-rat is offline   Reply With Quote
