Old 05-25-2016, 10:17 AM   #21
ReeceyBurger123
Never Give Up !
ReeceyBurger123's Avatar
City & State: Telford
My Country: Britain
Line Voltage: 240 VAC 50Hz
I'm a: Student Tech
Default Re: RUNTK 5351TP No Picture Failure
Maybe, hopefully not the same case for mine if so Im out of luck.
ReeceyBurger123 is offline   Reply With Quote
Old 05-25-2016, 10:51 AM   #22
flocko
City & State: dover
My Country: uk
The KL5T3067 can also fail? but its a good bet that if the VCC 3.3v is missing changing the ISL9860 will do the trick, As soon as there was a good supply of new boards. I stopped repairing them, with the customer paying repair cost I just brought new.
flocko is offline   Reply With Quote
Old 05-25-2016, 11:54 AM   #23
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Yes read what the other chap said further up.
Old 05-25-2016, 01:00 PM   #24
flocko
City & State: dover
My Country: uk
I did read the above? I am just adding that if you do not have the VCC 3.3v the chances are its the ISL9860 that has failed or has not been fitted correctly.And not the KL5T3067 that is at fault
Old 05-26-2016, 03:00 AM   #25
angel-boy
City & State: Constanta
My Country: Romania
reball . change again isl . still no image. any help ?
angel-boy is offline   Reply With Quote
Old 05-26-2016, 05:08 AM   #26
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Its really hard to say with out the board here in front of me sorry :L
Old 06-30-2016, 08:12 AM   #27
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Well chaps good news here, replaced Ic200 and the set works Will upload pictures of work later.
Old 09-28-2016, 05:07 AM   #28
rtstorm
rtstorm's Avatar
City & State: Croatia, Osijek
My Country: Croatia
Line Voltage: 230V 50Hz
Hey is it the same board RUNTK 5351TP ZA and RUNTK 5351TP ZA model?
I need to order new board and i have ZA model but seller have only ZZ model
...the quieter you become the more you are able to hear...
rtstorm is offline   Reply With Quote
Old 10-11-2016, 02:38 PM   #29
rtstorm
rtstorm's Avatar
My Country: Croatia
Hey i find new bard and install it, i get screen but have some lines. Any ideas what is this?
Old 10-26-2016, 06:51 AM   #30
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Images coming soon totally forgot. Also RTStorm thats a failed panel them lines
Old 10-26-2016, 07:45 AM   #31
rtstorm
rtstorm's Avatar
My Country: Croatia
But wheb i disconect one flat cabke the line are gone
Old 10-26-2016, 08:02 AM   #32
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Yeah thats because the shorted panel drive isnt getting power so it cant pull the lines up.
Old 10-26-2016, 10:02 AM   #33
victor_cj
City & State: Cluj-Napoca
My Country: Romania
Line Voltage: 230VAC 50Hz
Originally Posted by angel-boy View Post
i have a RUNTK 5351TP , i change the IC200, ISL, but still no image, the fuse is good, any ideea ?
IC100 KL5T3067
http://www.elforum.ro/topic/119716-t...40f5500/page-2
The art of fighting without fighting
victor_cj is offline   Reply With Quote
Old 01-21-2017, 01:12 PM   #34
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Forgot to upload pics of this fix, here they are just forgot. One by one as Vbullet will not let me do more than one at a time on mobile device. First one is old Ic removed.
Old 01-21-2017, 01:15 PM   #35
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Second Ic changed flux residue still present.
Old 01-21-2017, 01:19 PM   #36
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Third is Ic with removed flux.
Old 01-21-2017, 01:22 PM   #37
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
Fourth pic is heatsink added to Ics.
Old 01-21-2017, 01:24 PM   #38
ReeceyBurger123
Never Give Up !
My Country: Britain
I'm a: Student Tech
5th is working image after I pc change, was preformed ages ago never did a vid and forgot to upload image
Old 01-21-2017, 01:39 PM   #39
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
I'm a: Hardcore Geek
I think I'm having the exact same issue (ReeceyBurger just replied to my own thread just a few minutes ago - cheers ). I think I'll try measuring VCC 3.3 first with and without the buffers attached. If I get nothing, the ISL driver is most likely busted.
From what I read on the forum the other chap linked to (I fortunately speak native Romanian ) I should also take readings of VGH and VGL, though I'm not entirely sure what they should normally read. Lots of info here, so hopefully I'll manage to pull though
EDIT: upon reading the Romanian forum thread more carefully, I noticed VGH and VGL should be around 35v and -6v respectively (or real close to that)...is this correct ? The fellow over there didn't have T-con issues after all, so I can trust those readings to be pretty close to what they should normally be - it was a shorted driver on the right side of the screen which dragged down the VGH bus.
Wattevah...
Dannyx is offline   Reply With Quote
Old 01-21-2017, 01:47 PM   #40
Dannyx
CertifiedAxhole
Dannyx's Avatar
My Country: Romania
Yeah, heatsinks are a must as far as I'm concerned...boggles the mind as to why so many brands "omit" to add them ! Planned failure at its finest is what I call that ! >_>
