Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 11-13-2019, 07:40 AM   #1
decayed.cell
City & State: Melbourne
My Country: Australia
I'm a: Knowledge Seeker
Default Seasonic X-560 and Corsair AX650 - fail to power on after a week of use
I have a Seasonic X-Series 560W and a Corsair AX650 here which suffer the same symptoms (they are based off the same platform, so I guess its not surprising).
They will power on a computer fine for a few days. But after a few days, they refuse to power on unless the switch at the back is flicked off and back on again. Eventually, the power supplies will stop working. However, if left alone for approximately a week or so, they will power on again properly and the cycle begins again.
What could be the cause of this issue?
decayed.cell is offline   Reply With Quote
Old 11-14-2019, 01:22 PM   #2
Thermaltake
City & State: NY
My Country: US
I'm a: Hobbyist Tech
Default Re: Seasonic X-560 and Corsair AX650 - fail to power on after a week of use
Have you checked inside of the PSUs if there are any strange burned things or any bulged capacitor/s ?
Thermaltake is offline   Reply With Quote
Old 11-24-2019, 09:47 AM   #3
CapLeaker
Leaking Member
CapLeaker's Avatar
City & State: Atlantic Canada
My Country: Canada
Line Voltage: Ground, 0Hz
Check all the caps near a heat sink. They may look good, but still be high esr.
CapLeaker is offline   Reply With Quote
Old 11-28-2019, 01:56 AM   #4
Quaddro
Tukang Kentu
Quaddro's Avatar
City & State: Yogyakarta
My Country: Indonesia
Line Voltage: 220VAC 60Hz
i've found a few case like this.
according my experience, this is can be weak pwm/apfc controller ic.
Try to heat the ic's in primary and secondary with hot air station.
One by one.
Quaddro is offline   Reply With Quote
Old 11-30-2019, 01:42 AM   #5
decayed.cell
Quote:
At a quick glance nothing appears to be burned, and no bulging capacitors
Last edited by Per Hansson; 11-30-2019 at 04:43 AM.. Reason: Offsite image uploaded
Old 11-30-2019, 02:37 AM   #6
decayed.cell
One by one.
I think I'll just try replacing the ICs instead. ICE2QR4765Z and APW7159A
Old 11-30-2019, 01:01 PM   #7
Quaddro
Tukang Kentu
Quaddro's Avatar
weak ic can be cause of broken smd parts, for example smd tantalum capacitor.
That's why i suggest to blow the ic with hot air first.
If it working after hot air, we can make sure tantalum is the culprit..
Just replace all tantalum in daughter board.
If the still persist, then the ic is the source of problem.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
