Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Thread Tools Display Modes
Old 02-19-2019, 08:45 AM   #1
storexxm
City & State: 1180
My Country: Vienna
I'm a: Knowledge Seeker
Default PS4 Controller acting weird
Hello folks.
I habe a problem with my ps4 controller.
First here a video of what it is doing:
https://www.youtube.com/watch?v=tNYjTBw_wX4
It presses ITSELF the R2 bottom. Mostly when i move the analog stick to the left. What i already did:
I dissasambled the whole controller (only the board with the two analaog sticks left) and the problem is the same. So now my question:
can the problem be the stick itself (but how he can send the signal to press the R2 Bottom) or is it something else that wont be possible to find (a chip or controller or whatever)
Would be really cool when someone can tell me IF there is the chance to reapair it by changing the analog stick.
thanks to all in advance.
greetings, Alex
storexxm is offline   Reply With Quote
Old 02-19-2019, 12:48 PM   #2
diif
City & State: Midlands
My Country: England
I'm a: Professional Tech
Default Re: PS4 Controller acting weird
Nothing to do with the analog, it's the foam pad under the Sony flex.
diif is offline   Reply With Quote
Old 02-19-2019, 01:33 PM   #3
storexxm
City & State: 1180
My Country: Vienna
I tried it with the board only... the buttons weren't even connected and it did the same. Also I tried to put something between the foam and flex. No change :/
Old 02-20-2019, 02:34 PM   #4
diif
My Country: England
Which version of the controller do you have ?
I know if there is no Sony flex on the current version (5) then L2 and R2 activate.
I'm in a job where I repair between 30-60 controllers a day. It's common to see L2 or R2 activated. Removing the foam, rotating it 180 degrees and refitting cures this issue.
Old 02-20-2019, 03:14 PM   #5
storexxm
City & State: 1180
My Country: Vienna
but when i disconnect the flex its not really activated... its jumping around from 0 and 1... and also the left trigger isnt working properly...
i made another video of it
https://www.youtube.com/watch?v=8ZXrKKQ2IZY
a friend told me this can be noise signals caused by a broken component
when i move left its jumping around and after a half second it stays still...
when i move again it jumps and stands still after a half sec..
Old 02-20-2019, 03:15 PM   #6
storexxm
City & State: 1180
My Country: Vienna
Quote:
Originally Posted by diif View Post
which version of the controller do you have ?
I know if there is no sony flex on the current version (5) then l2 and r2 activate.
I'm in a job where i repair between 30-60 controllers a day. It's common to see l2 or r2 activated. Removing the foam, rotating it 180 degrees and refitting cures this issue.
jdm-04011-3
Old 02-20-2019, 03:42 PM   #7
storexxm
City & State: 1180
My Country: Vienna
Old 02-22-2019, 01:34 PM   #8
diif
My Country: England
Taken today for you.
Old 02-25-2019, 08:41 AM   #9
storexxm
City & State: 1180
My Country: Vienna
okay.. looks completely the same.. i sold is as a broken controller.
maybe someone else can repair it. thank u anyway-
Old 03-01-2019, 06:55 PM   #10
llonen
City & State: united kingdom
My Country: hampshire
Line Voltage: 240 VAC 50Hz / 110 VAC 50 Hz and 415 VAC 50Hz
Could be a bad analogue controller I suppose measure the pots, I see a few of these come in weekly for repair, and have replaced more than a few of these controllers. It brings in a income along with the customisation and upgrades I off to clients, I certainly would not want to be working on 30 or more daily though.
llonen is offline   Reply With Quote
Old 10-31-2019, 06:23 AM   #11
MCorgano
City & State: Calgary
My Country: Canada
For the people who do not know, the analog sticks and the triggers share some of their inputs for the microprocessor. The button ribbon (flex pcb with the button traces) keeps part of the analog circuit high / low (don't know which) and that keeps the triggers from being changed by moving the sticks.
The issue is easy to reproduce - take any good controller, remove / disconnect the button ribbon, and then move the sticks. You'll see exactly the same behavior
Given these two pieces of information I'd go out and say that part of the flexible button pcb (I call it a button ribbon) has been damaged and disconnected, letting the pin of the microprocessor that the trigger and analog stick share float causing the issue. Replacing the button ribbon with a new one of the correct model (look for slim / pro, or jdm-040 or even just 040 when searching) should fix the issue.
MCorgano is offline   Reply With Quote
Old 11-03-2019, 11:29 AM   #12
xmetal
Looking at your board it looks like you might have some liquid damage at this point.
https://www.badcaps.net/forum/attach...1&d=1572802025
xmetal is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
