Dell alienware 14 la-9201p bios needed
    Hi.guys.i need help. If someone in this forum has clean DELL Alienware 14 M14X R3 - P39G VAR00 - LA-9201P BIOS.I need it to remove this laptop bios password.
    Can someone kindly enough to share.TQ
    Re: Dell alienware 14 la-9201p bios needed
    up thread.please help
      can you make a dump ?
        how to make a dump buddy?
          are you have bios programmer ?
            if you wanna to remove your password you must dissembling you laptop then pull up ec and bios then make a dump by using bios programmer then program a new one
              yes.i have it
                i have disassembly the laptop
                  i have download the bios http://www.dell.com/support/home/us/...&categoryId=BI
                  file from dell but no .bin in there
                    oky you can search at ic 1 and 2 in pic
                      you must extract it then edit it as old bios dump
                        read old bios and ec then upload those files to me
                          i know the bios i.c. it was 2 bios i.c. one is E.C bios.but how can i extracted the bios from .exe file?.when i extracted it. no file related to bios is found there. what program u use to dump the bios file.?
                            You need a bios programmer to dump/read or write !
                              Hi, sky. this is actual bios.bin that i have retrieve from bios i.c.please take a look. ok https://www.mediafire.com/?5jvndo2vaxb6b7r
                              And this is Bios.exe from Dell website http://www.mediafire.com/download/ea...5/AW14XA09.zip
                                Up thread.please help
                                  need help.guys
                                    in dell web bios update only main bin 8mb file
                                    i dont know about other file
                                    Im Back... sort of...
                                      This alienware laptop have 2 bios i.c.
                                        I have try ur bios files. It was the same with mine.bios laptop still have password.Need help guys
