samsung syncmaster SA350 no picture
    Re: samsung syncmaster SA350 no picture
    I guess you could try it... but without a firmware at all it may not detect at all and still not work.
    -David VanHorn
      Hey!
      I have two Samsung s27a350h monitors, that don't show any pictures, and won't accept a firmware update. I guess there is a EDID error. As I have understood, I need an EDID-file from a working similar monitor, but I can't find it anyware. Anyone here that can help me? Or may I use EDID-data from a different Samsung monitor?
      The problem is that the computer recognizes the monitors, but the picture won't appear. I have tried windows vista --> 10 and Fedora 22. The "can't find the input" jumps around the screen. So the panel works fine :-) I want to try the EDID thingi before I use $100++ on new boards.
      If I post the Raw data, will anyone here recognize any errors?
      -Mikael
        You can post the data and see, sure.
        -David VanHorn
          I try to upload the report for both the HDMI and the VGA EDID.
          It would be great if you could check it out.
            Hello, i have save problem with LSA350H (first post), randomly it works correct, but when i turn it off LCD not start, just red LED, today i downloaded corrupt .bin from EEPROM (at the attachment), but i cant find new correct .bin file, found it on ebay like a new preprogrammed EEPROM. Can somebody post downloaded correct .bin from EEPROM? Thank you
              Hm.... I read the first dump into edid-decode that I discovered through here: http://www.blaicher.com/2012/06/howt...bus-pirate-v4/
              Result:
              Code:
              Extracted contents:
              header:     00 ff ff ff ff ff ff 00
              serial number:  4c 2d ce 07 30 35 30 30 29 15
              version:     01 03
              basic params:  80 3c 22 78 2a
              chroma info:   f8 31 a4 56 4f 9d 27 0f 50 54
              established:   bf ef 80
              standard:    a9 40 81 80 81 40 81 00 95 00 b3 00 71 4f 95 0f
              descriptor 1:  02 3a 80 18 71 38 2d 40 58 2c 45 00 56 50 21 00 00 1e
              descriptor 2:  01 1d 00 72 51 d0 1e 20 6e 28 55 00 56 50 21 00 00 1e
              descriptor 3:  00 00 00 fd 00 38 4b 1e 51 11 00 0a 20 20 20 20 20 20
              descriptor 4:  00 00 00 fc 00 53 4d 53 32 37 41 33 35 30 48 0a 20 20
              extensions:   01
              checksum:    5d
              Manufacturer: SAM Model 7ce Serial Number 808465712
              Made week 41 of 2011
              EDID version: 1.3
              Digital display
              Maximum image size: 60 cm x 34 cm
              Gamma: 2.20
              DPMS levels: Off
              Supported color formats: RGB 4:4:4, YCrCb 4:2:2
              First detailed timing is preferred timing
              Established timings supported:
               720x400@70Hz
               640x480@60Hz
               640x480@67Hz
               640x480@72Hz
               640x480@75Hz
               800x600@56Hz
               800x600@60Hz
               800x600@72Hz
               800x600@75Hz
               832x624@75Hz
               1024x768@60Hz
               1024x768@70Hz
               1024x768@75Hz
               1280x1024@75Hz
               1152x870@75Hz
              Standard timings supported:
               1600x1200@60Hz
               1280x1024@60Hz
               1280x960@60Hz
               1280x800@60Hz
               1440x900@60Hz
               1680x1050@60Hz
               1152x864@75Hz
               1440x900@75Hz
              Detailed mode: Clock 148.500 MHz, 598 mm x 336 mm
                      1920 2008 2052 2200 hborder 0
                      1080 1084 1089 1125 vborder 0
                      +hsync +vsync
              Detailed mode: Clock 74.250 MHz, 598 mm x 336 mm
                      1280 1390 1430 1650 hborder 0
                      720 725 730 750 vborder 0
                      +hsync +vsync
              Monitor ranges: 56-75HZ vertical, 30-81kHz horizontal, max dotclock 170MHz
              Monitor name: SMS27A350H
               Has 1 extension blocks
              Checksum: 0x5d
              Assuming that Hex dump came straight from your EDID ROM, then your EDID is probably OK. Might be something else wrong here although I don't know what. Maybe you have a system ROM problem.
              Have you tried with something that will force output even if the monitor is not detected?
              -David VanHorn
                Are you sure it's corrupted? If you can't find a file, you probably have to buy that new EEPROM and compare.
                -David VanHorn
                  S27A350H firmware as attached .
                  winbond w25x40
                    Thanks edwardnasun! You saved me a lot of time and money!
                      winbond w25x40
                      how to install it?
                        Hi everybody, maybe this information helps somebody:
                        I had the same problem with the monitor and the update tool said "firmware up to date" like for many others here.
                        The solution: the update tool seems to not work on Windows 10! After trying the same thing on a Win XP machine (nothing else changed), the update tool from samsung worked like I hoped and the monitor works again!
                        (credit to JonathanAlstad here https://www.badcaps.net/forum/showpo...3&postcount=27 to giving me the right idea)
                          Thank you
                            merci
                              winbond w25x40
                              thank you
                              works also in s24a350h
                                Hello
                                I need the dump of a Samsung sa350 S22A350B monitor
                                thank you
                                  Originally posted by didouche1200 View Post
                                  Hello
                                  thank you
                                  S22A350B dumps
                                    I can confirm that the firmware update .exe supplied by Samsung
                                    does NOT WORK with:
                                    WIN10-64 => "no monitor to update or no monitor found"-message
                                    Win7-64 => bluescreen :O
                                    I set up an old notebook with WIN XP-PRO 32 and started the Samsung Firmware Update File:
                                    THIS WORKS 100% !!!
                                    I checked with both dead LS24SA350. Both are back in business now
                                    Here are the details:
                                    Both monitors were recognized by WIN10 and WIN7 via HDMI and VGA-port initially, but never showed a picture, only "check cable". I think that is a good sign though to move on with XP.
                                    The notebook succesfully used was a medion MD98200 with intel 945 chipset, intel GMA 950 gpu and WINXP-Pro 32 SP2.
                                    Appropriate XP-drivers had to be installed to activate the external VGA-Port in advance.
                                    The SA350 was then connected via the external VGA-Port of the notebook.
                                    The monitor installation file supplied by Samsung was then installed succesfully (choose analog).
                                    Then firmware update was initiated and everything went fine.
                                    After some minutes the updater finishes and the panel switches off.
                                    Just switch it on again and see the light
                                    Stay save
