Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
    Re: Dell E5570 - Bios / Clean ME ADM80 LA-C642P R1.0
    Originally posted by apostsamking View Post
    Pls it's still not displaying.
    Maybe I found the cause in the GBE region
    Become a Badcaps supporter
    Thanks to all supporters.
      My Motherboard No. Is ADM80 LA C641P Rev 1.0 (A00) 2015-10-23. No display Sir pls help.
        Please, claer me ME Region
          Here's your Clean file, hope it works fine.
          all donations are welcome,
            Thank's
              Hello. The bios is flashed, but it turns on twice. Can you extract the bios from the site? File attached
                I don't understand what you mean but if you want a new file from the official one, here it is.
                Your Service Tag in case you need it: 94WZ1G2
                  This bios working %100
                  For Dell E5570,ADM80 LA-C641P Rev 1.0 (A00)
                    Originally posted by peste View Post
                    try..
                    good 100% ok file
                      Bios request for dell e5570- starts up but black screen
                      Dell e5570.
                      m/b-ADM80 - LA C641P-REV 1.0 (A00)
                      S/No- CBPSNC2
                      The laptop starts up but nothing on screen, black screen.
                      cpu is getting warm.
                      Black screen on external thru vga,hdmi.
                      Lcd screen is tested working on another laptop.
                      I think this may be bios related issue.
                      Please can you help me sort this problem.
                      I have enclosed my faulty bios.
                        Re: Bios request for dell e5570- starts up but black screen
                        Originally posted by inkman View Post
                        Dell e5570.
                        S/No- CBPSNC2
                        Try the bios at post #2.
                          Dell e5570.
                          S/No- CBPSNC2
                          Try ...
                            The laptop is sorted now,its working no more black screen.
                            Thank you vesco356.
                            I can confirm that this bios bin is fully working .
                              Hello.
                              I have a problem with Dell E5570 (La-C 641 PREV. 1.0(A00).
                              At the beginning laptop has no answer to power button.
                              Then I flashed W25Q128 with clear ME firmware from #2 post.
                              Laptop began start and work normally.
                              After installing Windows10 - LAN (I219-LM) can't installed, Wi-Fi device is no visible.
                              I tried to flash another firmware with clear ME, but nothing changed.
                              Could it be relate with incorrect firmware or it's a hardware problem?
                              Original dump is attached, please help to repair it, if it possible.
                              In addition. I got laptop without hard drive, Windows 10 was installed on new SSD.
                                del.
                                  Originally posted by mbuser View Post
                                  Hello.
                                  At the beginning laptop was no answer to power button.
                                  Then I flashed W25Q128 with clear ME firmware from #2 post. Laptop began start and work normally. After installing Windows10 - LAN (I219-LM) can't installed, webcam and Wi-Fi device is no visible. I tried to flash another firmware with clear ME, but nothing changed.
                                  Hello try this me clean file and let me know what happen ...
                                    Sorry.. Webcam is working, only LAN&Wi-Fi trouble.
                                    If you want to edit or add something just use the edit button and do it, there's no need to make new posts one after the other!!!
                                    Markus1741, Lan/Wi-Fi troubles are indeed indication of ME Firmware problems but usually when the bios is not working at all (no boot) bios region gets corrupted rather then the ME region (or at least more often) so the bios rgn must be repaired/replaced first (before the ME Firmware cleaning) to make sure the bios will be OK at the end.
                                      Thanks. I didn't have this option.
                                        Really?
                                          Thank you very much, trouble is solved.
                                          Really?
                                          Posts were edit after your tutorial, thanks
