Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 06-19-2022, 08:09 AM   #1
karthur
City & State: Tuscumbia
My Country: United States
Line Voltage: 120VAV 60Hz
I'm a: Hobbyist Tech
Default Sanyo DP55441 - No brightness control
Recently picked up a Sanyo DP55441. Set has a few issues:
1. When I turn it on, I always have to select either "Store" or "Home" on the menu (see attachment).
2. It forgets which input I was using last, so I have to change the input setting everytime.
3. The controls for Brightness, Contrast, Saturation, Hue and Sharpness are not available from the menu (see attachment).
Besides these issues the set works good, no other issues that I know of.
I am thinking all three are related and its probably the main board. I have looked at the main board and the power board, but see no visible damage.
Any ideas?
karthur is offline   Reply With Quote
Old 06-19-2022, 08:31 AM   #2
lotas
City & State: Sochi
My Country: russia
I'm a: Knowledge Seeker
Default Re: Sanyo DP55441 - No brightness control
This is usually due to bad memory (Eeprom, Spi Flash).
lotas is offline   Reply With Quote
Old 06-19-2022, 09:12 AM   #3
karthur
How do I fix it?
Old 06-19-2022, 09:32 AM   #4
lotas
City & State: Sochi
My Country: russia
Quote:
Originally Posted by karthur View Post
How do I fix it?
If you have a programmer, then you need to unsolder this spi flash (from the photo of your motherboard, I no longer saw other Eeprom and spi flash). Read the contents in your memory and save the dump. Buy a new flash and load your saved dump into it and solder it in place of the old flash.
Old 06-19-2022, 09:46 AM   #5
dskall
dskall's Avatar
City & State: Bakersfield ca.
My Country: usa
Line Voltage: 120VAC 60Hz
https://www.shopjimmy.com/sanyo-431c...8aAkWZEALw_wcB
__________________
dskall is offline   Reply With Quote
Old 06-19-2022, 09:59 AM   #6
nomoresonys
City & State: midwest
My Country: U.S.
probably bad memory as mentioned, did you try an update and or factory reset?
nomoresonys is offline   Reply With Quote
Old 06-19-2022, 10:09 AM   #7
karthur
Quote:
I did do a reset from the onscreen menu, but I have not tried an update. Is there a certain key sequence to get into a service mode or some other way to get into a deeper reset?
I searched on Sanyo-av.com for my model No. There is no update listed there.
Old 06-19-2022, 10:30 AM   #8
karthur
Quote:
Here is a picture of my board. There are several of those on the board.
I don't have a programmer. Would one of these work?
Old 06-19-2022, 10:56 AM   #9
lotas
City & State: Sochi
My Country: russia
If you see microcircuits on the board 24Cxx, then this is Eeprom, if there are 25Xxx, then this is Spi flash, but the markings are not visible in the photo, rather these are DC / DC converters in the Sop-8 package. As for the programmer - yes it will do.
Old 06-19-2022, 11:04 AM   #10
karthur
Let me get the back off again and I will take a closer look.
Old 06-19-2022, 11:12 AM   #11
lotas
City & State: Sochi
My Country: russia
You can also look at the back of the board.
Old 06-19-2022, 11:19 AM   #12
lotas
City & State: Sochi
My Country: russia
Usually, the eeprom or spi flash is marked with a dot or a strip of paint (indicating that the microcircuit has been programmed and tested).
Old 06-19-2022, 11:25 AM   #13
karthur
The only one I found with "25" on it (see attachment) and it has the paint mark. I did not see any with "24" on them. Do I need to look on back of board for one with "24" on it?
Old 06-19-2022, 11:43 AM   #14
karthur
Went ahead and flipped the board over. Found this one with a paint mark on it too, Number on it reads 25L8xxxx if it matters. I think the xxxx is 036F, but its covered by the paint.
Old 06-19-2022, 11:45 AM   #15
lotas
City & State: Sochi
My Country: russia
Maybe, maybe not. But rather it is not there.
Old 06-19-2022, 11:51 AM   #16
lotas
City & State: Sochi
My Country: russia
On the other hand, we do not need 25xxx, it is rather responsible for scarlet (matrix settings).
Old 06-19-2022, 11:59 AM   #17
karthur
Both of them are 25xxx. Is the one on the front the one that possibly needs to be replaced? Are there certain specifications that I need to look for to replace it with? Surely there are other sources for this that are not $16.
Old 06-19-2022, 12:06 PM   #18
lotas
City & State: Sochi
My Country: russia
Wipe off the paint so that the full marking can be seen.
Old 06-19-2022, 12:40 PM   #19
karthur
Here is close-ups of both chips. The numbers are:
Front Chip
MXIC MX
25L3206E
M2I-12G
3F652000
L111676
Back Chip:
MXIC MX
25L8006E
M2I-12G
3E660500
Z105075
Old 06-19-2022, 12:59 PM   #20
lotas
City & State: Sochi
My Country: russia
For 16 bucks there is an already programmed flash, you need to find the same or an analogue (the size of the internal memory), they cost a penny.
https://aliexpress.ru/popular/mx25l3206em2i-12g.html
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums © 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
