Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Power Supplies and Power Supply Design
Thread Tools Display Modes
Old 10-10-2021, 05:17 AM   #1
pintglass
City & State: Congleton
My Country: United Kingdom
I'm a: Knowledge Seeker
Default DV-PF4E(UK) Power suppy repair
Hi
I'm trying to repair an internal power supply in a Hitachi DV-PF4E video/dvd combi player.
I've narrowed the fault down to Q1001 a N channel mosfet (2SK3566) which seems to be shorted, when powering the power suppy this takes out resistor R1043.
I don't have any of these mosfets but do have some FDPF5N50UT's would this be a suitable replacement?
I've attached the schematic for the DV-PF4E the power supply section being on page 88, I've also attached the datasheets for the mosfets.
pintglass is offline   Reply With Quote
Old 10-15-2021, 01:35 AM   #2
pintglass
Default Re: DV-PF4E(UK) Power suppy repair
I've replaced the mosfet Q1001 with the same part as was installed originally, but resistor R1043 keeps failing going open circuit.
Does anyone know what other component could be causing this?
Old 10-15-2021, 12:45 PM   #3
lotas
City & State: Sochi
My Country: russia
Rather, Q1001 struck again, since you did not check the entire strapping of it, if Q1001 pierces, then it carries off the strapping, check these components.
lotas is online now   Reply With Quote
Old 10-16-2021, 10:03 AM   #4
pintglass
I found that the transistor Q1003 was shorted between base and emitter so I replaced that and changed Q1001 again, but I'm getting a loud buzzing I think from T0011 the power transformer and still getting no output.
Old 10-17-2021, 07:25 AM   #5
pintglass
I do now seem to have output, the only voltage that seems low is the AL-30 all the others seem fine.
The buzzing is worse when the power supply is connected to the main board.
This text is from the service manual
When buzz sound can be heard in the vicinity of power circuit.
Check if there is short circuit on the rectifying diode and the circuit in each rectifying circuit of secondary side
and service it if defective. (D013, D014, D016, D018, D019, D1008, D1016, D1030, IC1002, IC1003, Q051,
Q053, Q055, Q056, Q058, Q1052, Q1053, Q1055)
Does this mean the rectifying diode's on the primary side?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2022
Powered by vBulletin ®
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
