Thread Tools | Display Modes |
#1 |
Computer Geek
City & State: Hell's Front Porch
My Country: USA
Line Voltage: 120/2/[email protected]
I'm a: Hardcore Geek
![]() Fast Internet connection highly recommended to view this thread.
So earlier this month, I decided to install some new firewall software on my firewall system (an Advantech UNO-3072LA from 2008) and get a proper firewall solution going instead of the hacky Shorewall... thing that I had running. I picked IPFire because it was basically the last Linux-based solution left that would still boot on x86. Equipped with an Intel Atom N270 CPU, it's stuck on 32-bit software, and is a huge limitation, especially considering that it has dual GbE NICs. In the process of configuring IPFire, I ran into a rather nasty problem: It has no idea what to do when I try to open ports to the outside world at the same time the web proxy is running. Which is a breaking limitation, so I needed to pick another firewall solution. Say hello, OPNsense. Thing is, that only boots on x86_64 CPUs, which this Advantech system doesn't have. Cue a (former) gaming computer from 2004. Equipped with an AMD Athlon 64 CPU, any modern Linux distro should boot on it. It was in 24/7 service from November 2004 until late 2018 when it was pulled from service due to a flaky SATA controller and a bad PSU. It remained out of service until November 2019 when it was very suddenly called upon to act as a bridge system to bridge the Tech Room's wired LAN to the home's WiFi network because the modem had moved, resulting in the unavailability of it's LAN jack. It was recommissioned and was in service from November 2019 until May of 2020. More home networking changes resulted in a nearby LAN port becoming available again, and the system was removed from service. It's been out of service since May of 2020, but it has been used for other things. It's original installation of Xubuntu 18.04 is still on it's main HDD, but it has since had a Maxtor HDD installed. That had Debian Testing installed on it, and that install was used for recovering the contents of a few hundred floppy diskettes. (Sidenote: That Maxtor drive, despite showing perfect SMART stats, is dog slow.) Since it was last used, it's had a few things piled on top of it, and it was nearly invisible in an odd corner of the Tech Room. Now to move the pile of junk, get the system up onto the table, and grab some photos before we start messing with it. Awesome side panel: Butt shot 1 (lots of legacy ports on this old motherboard): OOPS, clicked post too early. Carry on... Butt shot 2: Other side panel: Front panel door closed, feat. optical drive with disintegrating cover: Bottom of front panel: Front panel door opened: (Yes, that floppy drive is loosely sitting in the case.) ![]() And for the USB ports: The headphone jacks are nonfunctional. IIRC, the motherboard's audio controller is also dead. Now for some inside shots before partially stripping it to make working on it easier. Top-down case view: Both HDDs installed and cabled up: Also, I manually jumpered both drives for master/slave when I added the Maxtor drive. Installed expansion cards: See that heatsink? I had that attached to the wireless card's chipset because it would overheat and do all kinds of bizarre crap without it. GPU: Molex Madness. Lots of splitters and adapters here: I don't have a lot of time left this morning to work on this thread. More pictures coming up from last night later today.
__________________
Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them. ![]() My computer doubles as a space heater. Windows 10? Only if you like forced, buggy updates and 24/7 telemetry. Samsung = Seagate = Seatrash = Trashgate Don't buy Seagate drives. Don't use Seagate drives. If you have any in service right now, make plans to replace them ASAP. SMR = Slow Magnetic Recording Avoid SMR, buy CMR drives instead. SMR is easily a 15+ year step BACKWARDS in HDD speed. Permanently Retired Systems: RIP Advantech UNO-3072LA (2008-2021) - Decommissioned and taken out of service permanently due to lack of software support for it. Not very likely to ever be recommissioned again. Last edited by TechGeek; 01-27-2021 at 06:43 AM.. Reason: More pictures b/c I hit post too early. |
#2 |
Computer Geek
My Country: USA
![]() More inline pictures incoming. I took these as I partially stripped and reconfigured the hardware.
In the process of partially stripping the computer, the faceplate on the optical drive completely disintegrated to smithereens. As a result, I moved it down a bay so it's protected from junk getting inside. Also, I removed the FDD as it won't be needed anymore. Ouch. The IDE connector on the optical drive really didn't want to let go of the cable. Partially stripped. These won't be returning to the system. PSU reinstalled. The lonely 40GB Seagate reinstalled and cabled up. ODD installed and cabled up. As previously mentioned, it's been moved down a bay to protect it since it no longer has a faceplate. Wireless card removed and slot blank installed. I prefer to close up any and all open slot blanks on a system when I can. It's aesthetically pleasing and helps keep junk out of it, especially when it's not in use. Open slot blanks are a lot of reasons why roaches and rodents get into systems and tear them up. PSU cabling ready to be hooked back up. I didn't hook it back up because there were a couple of pictures to be taken and I was about done messing with it for the night. Had to mess up some of my cable management to get the LAN cable to reach the FE controller, which was installed at the very bottom of the case so it could be in the faster PCI slot on the motherboard, as indicated by the orange-colored slot. Ethernet cables disconnected from old firewall system. They were reconnected shortly after this, likely for the last time. Yes, it's still on. Yes, those are LED fans hot-glued to the side of it to keep it cool. ![]() Now to throw it back together, hook it up, and get OPNsense installed and configured on it. |
#3 |
Solder Sloth
City & State: CO
My Country: USA
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
![]() LOL I'm currently working with one of the exact same case, was wondering...
This case is obsolete! Why? The HDD slots cannot take SATA disks ![]() Why? Well, unless you have 90° SATA connectors, both power and data, you can't close the side cover if you have SATA hard drives installed there ![]() I ended up having a few disk rails printed as I didn't have any and couldn't figure out a way to incorporate deeper SATA connectors and still able to close the case without flexing and damaging the cables. BTW, there was a P4 MB in here, alas it wasn't stable. I replaced it with that P3 I was talking about in this case. I have an Athlon XP2100+ somewhere but the P3 could handle 1.5GB RAM, the XP2100+ could only take 1GB ![]() Last edited by eccerr0r; 01-27-2021 at 08:27 PM.. |
#4 | |
HC Overclocker
City & State: Singapore
My Country: Singapore
Line Voltage: 240VAC 50Hz
![]() Quote:
also u have bulging teapos on the pci slot above the orange one. better recap those lest the installed pci cards take a dump from the bad caps!! ![]() ![]() |
#5 |
The Boss Stooge
City & State: Salem, MO
My Country: United States
Line Voltage: 240V @ 60Hz
I'm a: Professional Tech
![]() Didn't even check the caps?
__________________
<--- Badcaps.net Founder & Owner Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#6 | ||
Computer Geek
My Country: USA
![]() Quote:
Quote:
Didn't even notice the bulging caps. If/when I have the money and time to down the system to send the board off for a recap, I'll go ahead and do that. Which, depending on circumstances, may be soon. |
#7 | |
The Boss Stooge
![]() Quote:
#8 | ||
Solder Sloth
City & State: CO
My Country: USA
![]() Quote:
I didn't see any way for the cable end of the disks to be on the inside, the cable end must be on the outside next to the access door. Quote:
![]() Well as for curiosity's sake, I currently have 4 PATA HDDs, a 4mm DDS2, and a 5 disk SCA backplane with 4 SCA disks in this chassis. Yes, can fit a lot of drives... but no, all obsolete ![]() Last edited by eccerr0r; 01-28-2021 at 01:44 AM.. |
#9 |
SNES-powered
City & State: Bacau
My Country: Romania
Line Voltage: 230VAC 50Hz
![]() I think most newer boards come in box with at least one (or two) 90 degrees SATA cable. I definitely remember I had to build a LGA775 machine with the same type of cages, and I had some spare 90 degree SATA cables. Made my life much easier and could make it look incredibily clean.
__________________
Main rig: Gigabyte B75M-D3H Core i5-3470 3.60GHz Gigabyte Geforce GTX650 1GB GDDR5 16GB DDR3-1600 Samsung SH-224AB DVD-RW FSP Bluestorm II 500W (recapped) 120GB ADATA + 2x Seagate Barracuda ES.2 ST31000340NS 1TB Delux MG760 case |
#10 |
Solder Sloth
City & State: CO
My Country: USA
![]() Just about every SATA cable I have are straight including power cables. It's rare that I see 90° bend cables, I think I've ever seen one or two ever. Well if you can get a whole set of bent cables - both data and power - then this case will work fine for sata, else it seems to fit PATA and the molex 4x1 power best.
#11 |
Computer Geek
My Country: USA
#12 |
Computer Geek
My Country: USA
![]() More progress. Got it back together and in it's place. Old firewall system is officially out of service for the first time since early 2018.
PSU fully cabled up. Since there's no floppy drive, I can plug the HDD directly into one of the PSU's Molex cables. 1GB of DDR1 RAM installed. All buttoned up. Doesn't that look plain awesome? Another butt shot. No more wireless card. Optical drive no longer exposed. Shutting the old firewall system down for the last time. Powered down... ...and power cut. Remains of the ODD's faceplate. Test setup. It's alive! First boot in 144 or so days. More XBLADE awesomeness. Killed the lights for these photos. This is where it really shines. Up and running on a USB keyboard. In it's new home. Online (on an Ethernet connection) for the first time in over 8 months. Had some trouble writing an OPNsense image to my USB drive. Either the downloaded file was full of nothing or it refused to boot for whatever reason. Don't expect to see much progress today. Will be pretty busy. Now all I have to do is install and configure OPNsense. There might be an interesting twist in terms of the motherboard, so stay tuned. |
#13 |
City & State: Some times Sunny Jacksonville FL
My Country: USA
Line Voltage: 120 Volts 60 HZ
I'm a: Knowledge Seeker
![]() Tech Geek
Very nice work
__________________
9 PC LCD Monitor 6 LCD Flat Screen TV 30 Desk Top Switching Power Supply 10 Battery Charger Switching Power Supply for Power Tool 6 18v Lithium Battery Power Boards for Tool Battery Packs 1 XBox 360 Switching Power Supply and M Board 25 Servo Drives 220/460 3 Phase 6 De-soldering Station Switching Power Supply 1 Power Supply 1 Dell Mother Board 15 Computer Power Supply 1 HP Printer Supply & Control Board * lighting finished it * These two repairs where found with a ESR meter...> Temp at 50*F then at 90*F the ESR reading more than 10% 1 Over Head Crane Current Sensing Board ( VFD Failure Five Years Later ) 2 Hem Saw Computer Stack Board All of these had ![]() All of the mosfet that are taken out by bad caps ![]() |
#14 |
Solder Sloth
City & State: CO
My Country: USA
![]() Just looked at the PSU in my xblade case... oh my deer...
#15 |
The Boss Stooge
#16 |
ghettomodmaster
City & State: Bulgaria
My Country: Bulgaria
I'm a: Student Tech
![]() I don't want to be a jerk, but I fail to understand why you use a PC that consumes 10x more electricity working as a router than simply buying Mikrotik.
The electricity bill will show you how this is not the best option. I also don't know what you need a web proxy.
__________________
Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me. 1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams Last edited by televizora; 01-28-2021 at 11:02 AM.. |
#17 |
Solder Sloth
City & State: CO
My Country: USA
![]() If it's also doing something else like being a shell box or dynamic content webserver, then it's not a big deal.
Also sort of depends where one is in the world, electricity is ridiculously cheap in some places. But yes, a PressHott probably isn't a good idea as a router. The Athlon64 I have probably isn't a good idea either (though it is a laptop.) But it's not horribly bad, if compared to something like HVAC, power is a drop in the bucket, even if the HVAC needs to cool that one computer too. |
#18 | ||
Computer Geek
My Country: USA
![]() Thanks. There's just something relaxing about this type of thing. Until the system refuses to cooperate with you.
Quote:
I need something better, so I'm making do with what I have until I can get funds to do a proper rebuild. Also, I need a web proxy for URL filtering. Quote:
#19 |
Solder Sloth
City & State: CO
My Country: USA
![]() Speaking of routers, I wonder how fast of a PC is needed to route 1Gbps from one ethernet port to another, using no hardware assist? Then with "decent" ethernet cards?
I'm figuring my Celeron 1200 is not fast enough... |
#20 |
City & State: Owensboro, KY.
My Country: USA
![]() Someone who read all that tell me how it was repurposed?
Thread Tools | |
Display Modes | |
