Hi everyone!
I'm wondering if any of you knowledgeable people can help me.
I have a pair of KRK Rokit 8 Gen 2's.
One of the monitors has really low volume... I have to put my ear right up to the speaker cone to hear the audio and this is with the volume pot on full blast.
I have taken out the amplifier to look for bad caps and I have replaced all the electrolytic caps on the preamp board with audio grade Nichicon caps and tested all the rest of the caps on the board with an LCR meter and they check out within spec. (all caps were removed from circuit whilst testing).
I think I have narrowed the problem down to the pre amp board because when I was checking for voltages, I touched one of the legs on a JRP4580D operational amplifier (this is the 2nd op amp in circuit) and I had loud sound like I have touched the end of an RCA cable whilst plugged into the speaker jack. I then took an 3.5mm to twin RCA cable splitter and plugged it into my iPod. I grounded one side and touched the same pin on the JRP4850D (which I believe is the 'out' leg) with the other RCA and I had good, clean, loud, normal sound but with no volume control as I believe the problem lies between the RCA connector, volume pot and the op amps.
I have also checked all zener diodes on the board. I haven't paid much attention to the resistors though as none of them are burnt up.... should I be paying attention to them?
There's 6 of these JRP4580D op amps on the pre amp board.
Does anyone have any idea what could be causing or has had the same issue and has repaired it?
Could it be the 4580D's? I can get these for around 27p each from an electronic component distributor, however I'd rather know what exactly is causing this issue and replace that rather than replacing everything.....
I have attached a diagram with the pin out of the op amps on the board and the pin that gives me sound is (IN2+)
Any guidance will be appreciated!
Thanks in advance.
Thanks in advance.
