So I go to use my main computer this morning and my primary monitor (Toshiba 32AV500U) decides to not display a picture. There's a backlight, didn't know about sound (sound is not routed to this monitor), but no picture. No menus of any kind. It is 100% responsive to remote commands. A quick Google search points fingers at the TCON. How do I test the TCON to prove that it's bad?
Toshiba 32AV500U: TCON failure?
Permanently Retired Systems:
Kooky and Kool Systems
sigpicTags: None
Re: Toshiba 32AV500U: TCON failure?
Yeppers, TCON fuse is blown. So I guess that signifies a bad TCON?Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
UPDATE 11/12/2018 20:11 CST
TCON board ordered. Will update Saturday when it's installed.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
Check the resistance on the t-con side and see if there is a short, if there is none, try replacing the fuse, you can just wire in a 1.5 amp fuse and see if it works, Sometimes the fuse just gives out without the t-con being bad
If the fuse blows, disconnect the ribbons between the t-con and panel and try again to be sure the panel is'nt the problem.Last edited by R_J; 11-12-2018, 08:18 PM.
UPDATE 11/15/2018 17:45 CST
Replacement TCON board installed and working.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
I've had similar happen before. Had 3 fuses go in a stereo receiver for no apparent reason. I'm guessing old age.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpic
