X550jx black screen but cpu heating up
    Re: X550jx black screen but cpu heating up
    Provided 3.3v and no change.
      Put pq3002 and wait for oscilloscope
        X2001 has 32khz clock stabil sinus
          Check xtal crystal oscillator 14mhz or 25mhz
          If not ok then replace crystal
          Signal sequence ends at pltrst#
          It will not tell about BIOS
          Check Chip select pin1 of PCH bios , frequency generated or not
          If not then bios chip is dead
          Pin1,2,5,6 these pins have signals , check via oscilloscope
          If all ok then you have problem with gfx supply ,it should be present when CPU core and ram is ok
          1.8v generated ?
          in previous post you mentioned
          VDD=0.9v ???
            Found solution
            12vsus is missing that is why suspwrdnack is low
            After 26 step check at output at step26 1.5vspowergood
              Found solution
              - 12vsus is 12.98v and stabil
              - rechecked 3vsus_pwrgd = 3.09v (3vsus and its actualy 3.32v ) is this correct?
                Hmm interesting
                3vs power good tied to high logic or 3.3v then it is ok 3.3
                What is voltage on all pads of pq3002, check via boardview, list pad value
                Voltage is still available at pq3002?
                Suswarn# active only when any sus voltage is missing
                Suswarn# is active and coming from PCH
                Remove battery and check with adapter plugin only as if you see power sequence change with battery plugin DC mode
                  Hmm interesting
                  - No suswarn found in PCH boardview
                  - pq3002 3.3v voltage is only found while AC plugin in and 3 led (power+capslock+numlock) are lit but when it turns of and turns on again with 2 led then NO pq3002 3.3v voltage found. pq3002 has only 16mv
                  - same voltages with AC and same with battery testing sequence
                    Suswarn# is suspowerdnack# check in schematic power sequence diagram
                    Pq3002 all pads value name and voltage it is 3pin
                    Pq3002 3.3 at first but then zero
                    Sus voltage is missing, without sus voltage laptop will not show display and if you check schematic power sequence diagram 12v is an input to three sus switch ICS
                    What do you mean turn off then on?
                      - Pq3002:
                      pin 1 16mV
                      pin 3 16mV
                      pin 2 GND 0V
                      When I plug in the AC connector (no battery connected)
                      then the laptop starts by itself immediately with 3 led constant lights (power+capslock+numlock) [at this point the Suspwrdnack is 3.3v]
                      then after 3 second the laptop shuts down and starts again by itself (2 led lights constant power+capslock) [at this point the suspwrdnack is 0v and stays that way]
                        Did you get oscilloscope?
                        If yes check 1.05 PCH supply , 5v,3v,12vs all supplies
                        Should not have ripple , should be clear DC line signal
                        Do not connect battery until laptop rectified
                        With help of board view check
                        All 12vs points which are available on board
                        Experiment
                        You have PCH_susack# 3.3v and stable?
                        With jumper wire or tweezers create connection between suspwrdnack and pch_susack# and then
                        Start laptop , do not remove jumper wire
                        Check voltage at suspwrdnack with jumper wire still available
                        If voltage stable you have issue at 1.2vs supply which is required for display out
                        If voltage drops PCH is dead
                          Experiment
                          - Yes the oscilloscope arrived. I will check for ripples...
                          - Ok will check for 3.3 with jumper wire.
                          - 1.2vs can't be missing I think because my board is "type LDP" (link below) and does not have 1.2vs eletronics at all.
                          https://ae01.alicdn.com/kf/Hb447dceb...cM.jpg_q90.jpg
                          - Another idea: Can it be that I have flashed a "Type LVDS" BIOS and motherboard does not power on because it lacks 1.2vs?
                            It can be simple bios issue yes
                            First check DC signals and clock at crystal
                              My oscilloscope can only measure tup untill 200Khz so i cannot check the 2 other crystal)
                              DC 3v, 5v, 12v are ok no big drops/rises or anything (checked for 15 seconds)
                                Flash good known normal bios
                                  Done BIOS programming, no change
                                    Bios is probably bad because testclip is faulty. And now i cant even switch off by power button. Repeat and be back...
                                      Bios is corrupted. Some parts are not writeable and always 0.
                                      I order a new bios and hope for the best.
                                      back when reprogrammed new chip.
                                        further: ch341a BIOS writer was faulty, BIOS is good. Ordered a new ch341a programmer.
                                          Verified BIOS writen.
                                          Now the status leds after powering on the laptop are:
                                          power + numlock + capslock and they all steady lit (no flashing)
                                          Cannot power off anymore by holding the power button. (written the previous bios and still the same)
                                          with oscillator checked BIOS pin 1
                                          shows 2 waving with multimeter after starting. (assuming CPU loads bios info)
                                          No values are changed on any measured sequence points
                                          Removed both +NVDD colis. No change
                                          Problem persist.
                                          WHAT NOW?? HELP!
