X550jx black screen but cpu heating up
    Re: X550jx black screen but cpu heating up
    Originally posted by stingerchamp View Post
    Check crystal oscillator
    If you have DSO or oscilloscope check 32khz clock available or not and keep it checking for 10sec
    Make sure voltage on rtc cell 3 voltage
    If you have xtal clock for PCH check xtalin and out for 14mhz clock available or not
    Waiting for oscillator... Be back when i have it
      You have board view
      Check this signal suspwrdnack is connected to which capacitor or which nodes
      Take snapshot and post
        You have board view
        in this board suspwrdnack is actualy just connect KBC to PCH nothing fancy.
        suspwrdnack also connects to +3VSUS_ORG (measured 3v) and connected through a 10kOhm resistor.
          Check resistance value of 10 kilo ohm resistor
          In ohm range
            In ohm range
            Checked and its 10KOhm exactly
              Hmm interesting
              At step 15 rsmrst# when goes up 3.3v pch_susack# goes up at step 16 and at step 17
              suspowerdnack goes up after 200msec delay so
              First check PCH_susack# goes up and it is constant
              For few seconds or drops
              Second if it drops we found the problem
              This resistor is connected to which parts means one side and other side
              Replace q3002 transistor
              and if you find nothing changed ,
              Otherwise , difficult but not recommend as last option
              Solution1: use a jumper wire and attach one end where PCH susack# and connect other to suspwrdnack
              Solution2
              Jump wire from
              +3VSUS_ORG to suspowerdnack
              If we had complete schematic diagram it could help
              Our goal is to provide 3.3 volt at suspwrdnack to check if it works or not
              Flashing a good bios also an option with clean me region
                Hold your thoughts I have to check something...
                  Q3002 does not exist,
                  "ME SUSPWRDNACK" and "ME SUSPWRDNACK EC" is just connected trough R3071 and its a 0 Ohm resistor.
                  I will check what you suggested and get back.
                    Found a Schematic that is not exactly for this modell but whatever I looked up on this was good and correct for my modell too:
                      Check voltage at r2134 and r2106
                      This schematic diagram has power sequence where at step 6 we have sus_pwrgd and step 7 is suspowerdnack
                      and step 8 is after 200ms pm_rsmrst#
                      These signals are powered by 1.8vs
                      I am sure if all other signals are present
                      This is absent due to one of q3001a or b is working in abnormal condition
                      Check q3001a mosfet and q3001b it is a dual mosfet 6 pin
                      N channel so require high voltage in this case 3.3 to turn on and one will work at a time
                      Check voltage on pin 2 , 3 ,6 ,5
                        Sorry if i misslead you, but my previous statement is good:
                        "ME SUSPWRDNACK" and "ME SUSPWRDNACK EC" is just connected trough R3071 and its a 0 Ohm resistor. Q3001a and Q3001b in this board is not present but jumpwired directly
                        But you gave me an idea:
                        previously I have checked PCH_SUSACK# is 3.3v constant so EC give this signal out but I did NOT checked the other side of the R2232 resistor that is going to PCH. I check if I'm home.
                          - PCH_susack# 3.3v from start and constant
                          - ME SUSPWRDNACK goes up to 3.3v then it drops to 0v and stays that way.
                          (no short on any of them)
                          What does this mean?
                            ME_SusPwrDnAck should remain 3.3 high as per sequence , should never drop down
                            What is connected to other side of r2232
                            Which schematic is correct ,this new you attached or posted in previous page
                            Q3002 is important as per diagram
                              PCH_SUSACK# is connected to PM_SUSACK through R2232
                              Unfortunatelly nor the schematic nor the Boardview is perfect for this model.
                              This is a minimalistic board and most of the components are missing and just connected trough direct 0Ohm resistors.
                              I'll try to make a good picture with high quality to make you a good baseline of this board.
                              I have no idea why ME_SusPwrDnAck goes down after 3.3v it does not makes sense to me. Its directly goes to KBC chip.
                              I have checked and its 0Ohm all the way through from chip to chip. No short to ground.
                                Q3002 missing and jumpered trough 0 Ohm resistor R3071 see picture1: SUSPWRDNACK_pic.jpg (516.9 KB).
                                R3071 pins
                                1 ME_SUSPWRDNACK
                                2 ME_SUSPWRDNACK_EC
                                Made picture of PCH_Susack area balow PCH to make you see how minimalistic this board is PCH_pic.jpg (533.0 KB)
                                  Check at previous step
                                  3vsus, 5vsus constant or dropping for 10sec
                                  If drops we are getting close to fault
                                    +3VSUS is steady 3V
                                    +5VSUS is steady 5V
                                    +12VSUS is steady 13V
                                      When it goes down again tweezers create connection between suspwrdnack and pch_susack and check but carefully
                                      We are providing 3.3 signal to pch to retain sus
                                        If it turns on then I have a bad PCH? Just asking ...
                                          Not exactly sure but another solution is put pq3002 and provide power there as per sequence
