Dewalt DC012 Shop Radio no Sound
    HI guys
    I am a total rookie when it comes to sound equipment, but have some limited electronics knowledge. I have a Dewalt DC012 Shop radio. The radio switch on, change channels, even search for radio channels, but it's got no sound. Nothing from the speakers. Both the speakers measures 5.8ohms.
    DO you have any idea what I can look for
    Re: Dewalt DC012 Shop Radio no Sound
    Start by upload good clear outside and inside pictures so we can see what we are dealing with.
      try plugging into aux .
        Hi guys
        Im sorry for the long time delay. Please find herewith pictures of the Power supply board and I think Sound board. The only voltages I could measure was on CN508.
        If ground is ground in Connector, then the 13V measured as 16.5V and the AC Det. as 9.86V.
        Thank you
          shorted caps near the amp chip
            did you try aux in yet ?
              Hi guys,
              Thank you for your help. I could fix my Shop Radio. I found one 470mF cap close tot the AMP chip, replaced it and now my Radio is working again.
              Thanks again
                I would recommend that you replace all the capacitors
                Especially if they are non brand capacitors
                9 PC LCD Monitor
                6 LCD Flat Screen TV
                1 Dell Mother Board
                15 Computer Power Supply
                All of these had CAPs POOF
                  What chip is the amp? I have a similar problem, except the volume is very low at full volume.
                    amp is under the aluninium plate that looks like wings
                      Thanks, I'll have a look through my radio.
                        https://www.badcaps.net/forum/attach...4&d=1581186515
                        Verify that you do have Voltages feeding that black connector CN508, also show us the pin names for the CN508.
                          Hi, I have the same DC012, no sound. Measured the output voltage of the power pcb assy (which feeds the radio pcb), supposed to be 13V, reads 16V (circled in orange).
                          Could this 3V prevent the radio board to function properly?
                          The visual check does not show anything damaged or burnt on all pcbs, except for the resistor (circle in red) where the pcb changed color. The color bars indicates a 15 ohms resistor which reads good. The two blue relays on the left get pretty hot too.
                          Thank's
                          Gilles
                            Ok, thank's to everyone. Project closed, radio sent to recycling center. Gilles
