please help toshiba c850 no display
    toshiba c850
    plf/plr/csf/csr rev :2.1
    no display but it work in crt conn
    when i connected to lcd monitor (crt ) work good and data and boot win
    but there is no data on it's monitor
    i changed screen but no new
    i changed i/o but no new
    reprogram bios but no new
    any another way ???
    Re: please help toshiba c850 no display
    You have to check your LVDS connector CN3000
    Pin 1 2 3 23 24 25 voltage You have to remove the motherboard for the Lap
      Check this link that have boardview file, seem close with your board.
      https://www.badcaps.net/forum/showpo...32&postcount=2
        thanks for help
        pin 1 = 0 v,
        pin 2 = 18v
        pin 3 =3.3 v
        pin 23 and 24= 0v
        motherboard out lap
          thanks for you
            Originally posted by ayooon_2010 View Post
            thanks for help
            pin 1 = 0 v,
            pin 2 = 18v
            pin 3 =3.3 v
            pin 23 and 24= 0v
            motherboard out lap
            your voltages are not correct
            pin 1.2 should be 3.3V
            pin 3 ok
            pin 23 24 19V
            pin 25 3.3V
            find out Q3000 test the pin S D G (pin 1 2 3)
            FOR PIN 23 & 24 find the PAD6000 test voltage that point you should get 19V
            Upload a pic of the LVDS connector
              High res image:
                thanks for help
                pin 1 = 0 v,
                pin 2 = 18v
                pin 3 =3.3 v
                pin 23 and 24= 0v
                motherboard out lap
                AYOOON
                the Schematic I have send doesn’t match for you Mob on/off have send you the correct one let's test again from the beginning
                  High res image:
                  thanks ON:/OFF for the bordview
                  cant open the file need help
                    cant open this also need help
                      Just extract it first, then drag and drop any file with extension .ASC (whatever you choose on folder TODs) on your favorite boardviewer software.
                        AYOOON
                        the Schematic I have send doesn't match for you Mob on/off have send you the correct one let's test again from the beginning
                        i cant open on/of file
                        the photo u asked
                        thanks
                          really thanks on/off
                            Thanks on/off working
                              test LVDS connector J4501
                              pin 1 2 4 38 39 40
